MAF Screen
Old Apr 2, 2007 | 12:35 PM
LT1_King's Avatar
MAF Screen
i have the cat delete on my 94Z A4 with the LM1. i was wondering if i were to take off the screen on the MAF would it make somewhat of a difference considering i have the cat delete? would breathe a little bit better? or is it not worth it? and what would i need to take off the screen. what tools would i need. thanx guys
Old Apr 2, 2007 | 12:39 PM
MTBeni's Avatar
Leave it. Do a search on screen or descreening and there is plenty to read.
Old Apr 2, 2007 | 01:14 PM
TobyZ28's Avatar
Leave it in. But if your still not convinced after searching, remove the C-clip to take the screen out, so you can at least put it back in when you realise youll never know for sure if later problems are because of an inaccurate maf
Old Apr 2, 2007 | 01:21 PM
LT1_King's Avatar
oh isn't this considered a free mod? it "helps" out your performance?
Old Apr 2, 2007 | 02:46 PM
2000GTP's Avatar
It is, but I don't know if there have been documented gains and if it did provide a gain, it would be so small that it would be unnoticed. The only free mods I would consider doing would probably be the ICM cooling mod and the TB Bypass.
Old Apr 2, 2007 | 02:47 PM
canuck94z28's Avatar
maf ends
Years ago i bought a product from IRS that had no screen/divider and my car definitely lost low end tq! I have had no problems w/ my stk one.BTW i just got pcm tuned and tuner said he could tune for it but the calibration,etc is unknown,so stick w/stocker.Also i didn,t have a LT1 scanmaster back then but i can sayi was probably too lean.
Old Apr 2, 2007 | 03:40 PM
CamaroRacing12's Avatar
i removed mine....didnt notice any loss...
Old Apr 2, 2007 | 04:06 PM
TobyZ28's Avatar
Do a search. Do a search. Do a search. Do a search. Do a search. Do a search.
Old Apr 3, 2007 | 12:58 PM
06lingenfelter's Avatar
mine ran the exact same. no problems but alos no "felt" gain. so i would leave it in.
Old Apr 3, 2007 | 12:59 PM
i actually heard its for the turbulance of the air flow. the honey comb shapes straighten the air out from coming in so fast giving you a smoother air flow. i wished i left mine in.
Old Apr 3, 2007 | 01:44 PM
f1camaro's Avatar
I also removed mine and felt nothing good or bad,so i would say just leave it in.
Old Apr 3, 2007 | 05:48 PM
oneclean97z's Avatar
"If it ain't broke, don't fix it."
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
