MAF dying
Old Jun 26, 2004 | 06:59 AM
doodad's Avatar
Unhappy MAF dying
Looks like my MAF is going. I did a search, but had no luck. Anybody know what the going rate is on a stock version? I can't see the advantage in a $300 Granatelli, but feel free to try and convince me.
Old Jun 26, 2004 | 08:07 AM
valter's Avatar
How do you know it's dying? You can get a stock one on http://www.gmpartsdirect.com part number 25008308 for $210.35 I don't think Granatelli will do any good for you. It's like "performance ignition coil" stuff
Old Jun 26, 2004 | 08:41 AM
doodad's Avatar
It keeps throwing code. Thanks for the info.
Old Jun 26, 2004 | 10:45 AM
gamecockfan04's Avatar
Try jiggling the connector with the car running and see if it stalls, or starts to. If it does then its probably just a loose wire, and would be a quick fix. However if you determine it is the MAF for sure, I would look in the for sale section and buy a good used one for probably $50 or so.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
