MAF Cleaning?
Old Apr 29, 2003 | 12:02 AM
  #16
ram air camaro's Avatar
maf cleaning
hey guys what do you think about cleaning it with alcohol? i think it will work what do you guys think?
Old Apr 29, 2003 | 01:50 AM
  #17
Lions3's Avatar
You shouldn't really need to. Any gunk that's on there will come off with a dry paper towel or a rag. Make sure you blow any dust off of it after though.
Old Apr 29, 2003 | 05:37 AM
  #18
magius231's Avatar
a procedure detailed on a Mustang site about doing this (their MAFs are very sensitive) talked about using alcohol and a Q-tip. Thats what I did, just soak the end of the cotton swab and lightly rotate it between your fingers on the MAF wires, being careful not to push at all. Worked great
Old Apr 29, 2003 | 06:58 AM
  #19
hairbear21's Avatar
I don't know how you can't get the carbon, etc... off by using a contact cleaner, since that is what it was designed for. You can also watch it come right off if you spray it, and it eliminates having to "wipe" or "rub" anything off. If you do a search, you will find a large number of people who have touched the contacts and either broke something or messed up the MAF. Stay safe and use a contact cleaner which like I said is approved for cleaning such dvices
Old Apr 29, 2003 | 07:06 AM
  #20
Mizz96Z28's Avatar
I shot mine with some carburator/TB cleaner and haven't had any problems whatsoever.
Old Apr 29, 2003 | 10:27 AM
  #21
Lions3's Avatar
Sounds good. But I'm just saying, when I took the MAF apart, and took the sensor section over to my work bench and sprayed it with contact cleaner, the dirt didn't go anywhere. It just got wet and dried. Just FYI.
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
