MAF circuit malfunction, must have help, PLEASE!!!!!!!!
Old Aug 19, 2003 | 09:50 PM
Blue96z28's Avatar
Unhappy MAF circuit malfunction, must have help, PLEASE!!!!!!!!
Exact problem:
Car has rough idle, but does'nt vary in rpm at idle, and gets bad gas mlg, and has a slight miss throughout the powerband thats the worst between 1000-1500.
Awhile ago when my car still had stock airfilter and box, i started my car up in a heavy rain and drove a couple miles and the SES light came on, so i took it to get scanned @ autozone and it said either p101 or p 010 MAF circuit malfunction. So of course I cleaned the connections and checked the wires and they were good, so I put it back and on the way home it went off and did come back on for 15k mi.
Recently, I cleaned my MAF and noticed a instant difference and gas mlg and response, then slowly got worse and the miss has better getting worse too.
So today I was driving and after about 25mi the SES light comes on out of nowhere, so I go straight to autozone, about 25mi away, and it says the same thing it did before. So out of theory i unpluged it and started it up and it ran the same as it has been, with the same miss and everthing, but i didnt drive it, just idled it.
Anwayz, my question is, could a faulty MAF cause the missing problem and everything? Does anyone have experience with this code?
One more question, my friend has a 95 3.4v6 firebird, can I use his MAF to test with?
thanks for all the help
Old Aug 20, 2003 | 09:20 AM
Blue96z28's Avatar
Anybody please. TTT
Does anyone know if I can use my friends MAF off a 95v6 firebird to test with? Are they different?
Anyone with MAF problems? rough idle/very slight missing?
Old Aug 20, 2003 | 07:32 PM
Blue96z28's Avatar
I refuse to believe that no one knows the answer to atleast one of my questions? PLEASE
Old Aug 20, 2003 | 07:48 PM
1994CamaroZ28's Avatar
I got a ported one laying in my garage id let you borrow worked fine on my car, send me a message on aim and we'll go from there.
Old Aug 20, 2003 | 09:05 PM
Teal94Z's Avatar
Just sounds like your maf is going bad, if you harm the small wires at all inside, the MAF is done....
Old Aug 20, 2003 | 09:11 PM
Blue96z28's Avatar
How do you guys cars run without the MAF plugged in. I understand that it should run rough, its missing an important part of the vehicle, but it runs exactly the same it seems, with or without it. But the SES light is off again now.
Old Aug 20, 2003 | 09:56 PM
turbo_Z's Avatar
the car should run pretty close to the same with or w/o the MAF sensor plugged in unless the MAF is really messed up. I had a bad connection in mine which would cause it to lose contact with the MAF and throw an SES light. when this happened it was pretty obvious since the car would nearly die on me and it bucked really hard. i rebuilt the connector and never had a problem since.
Old Aug 20, 2003 | 11:18 PM
RENE95Z's Avatar
Just my .02, but you may want to check your MAP sensor also. Pull it off and clean it up and see what happens.
Old Aug 21, 2003 | 11:31 AM
Blue96z28's Avatar
I did not know that the MAP sensor was serviceable? What kind of contact surface does is have? I will defenetely try that, as I have seen a few posts about the results of a bad MAP. Does the sensor have a gasket underneath?
Old Aug 21, 2003 | 12:40 PM
TobyZ28's Avatar
You can pull the map off and put it back on with just a screwdriver. Theres a rubber nipple seal thing on the end, but it shouldnt break or anything when you take it out.
I'm not sure how effective spraying electronic cleaner down the map is... didn't do a hell of a lot for me, but then again i still havent found out whats wrong with my car, the map was probably just fine.
Double aught
Oct 2, 2015 11:29 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
