Which MAC's should I get for my car?
I've decided on getting a set of mid-length headers for my car. I know I could go with longtubes, but ground clearance and cats are my biggest issues. The roads in my area suck, and a lot of the store entrances have inclines and speedbumps. And I know that my exhaust would sound like pure crap without the cats to tone down the rasp. Plus, my dad's a cop, so I need cats anyway.
My car is a 97 with the dual cats. I see that MAC offers both single cat and dual cat mid-length headers.
Now, the dual cat header/y-pipe costs $729.99. http://fasttoys.net/shop/product_inf...roducts_id=476
The single cat header/y-pipe is only $439.99. http://fasttoys.net/shop/product_inf...roducts_id=475
That's a $290 difference. Could I use the single cat headers on my 97 without any problems, other then just buying one high-flow cat and having it welded on after the y-pipe? I think I read somewhere that the cat-back exhaust set-up is different between the 93-95 and 96-97 cars, is that true? What I have to do in order for the y-pipe/cat to have them line up with my Borla cat-back?
Re: Which MAC's should I get for my car?
I'm not sure you have a choice, i think you have to go with the dual cat... but i would definitely go with two cats if you do have a choice. You're guaranteed more HP with two cats over one.
yep like someone else said, get the single cat headers, less restrictive then the dual cats.
you will need to do 1 of these 3 things also, get o2 sims for the rear o2 sensors, get them tuned out with a custom tune, or have 2 bungs welded in after the cat for them...
cheapest would be the o2 sims
Originally Posted by Camarocracy
I probably should have added that I don't have emissions testing in my county. [But other counties in Ohio do].
There is zero emissions testing [visual or sniffer] in my county. But the police will still give a ticket if they find no cat, especially the state cops.
I converted mine over to the single cat style. I'm running an o/r pipe (no cat). I'm in Ky. and there are no emmissions sniffing. Maybe go with a hi-flow cat or just gut the factory one so it passes the visual test. Macs are damn good headers, great plug access. here's a link with some pics
http://gallery8926.fotopic.net/show_...n.php?id=23663
Definately go single cat if you can [I dont see why you couldnt as long as you have a cat]. I can only wonder why you dont consider some RK Sport Mids since they are going to have larger primaries and be a better supporting mod for that cam your talking about getting. Plus they are ceramic coated and only $450. $20 more for coating and larger primary tubes. Nice thing about either setup is that you can buy a Off road pipe that bolts in place of the cat if you feel like dropping it for the track or race.
-Dustin-
-Dustin-
-Dustin-
-Dustin-
