mac mids or jet hot lt's
Old Dec 9, 2003 | 09:22 AM
gritter's Avatar
With the same mods on a car what would the hp difference be between jet hot lt's and mac mids?
Old Dec 9, 2003 | 10:01 AM
ZDriver96's Avatar
long tubes and new ypipe... no doubt they are better.
Old Dec 9, 2003 | 01:47 PM
gritter's Avatar
i know they'll be better, the question was what's the HP difference?
Old Dec 9, 2003 | 01:50 PM
ZDriver96's Avatar
your asking too general of a question..
On a stock lt1 maybe 10hp plus another 8hp with offroad ypipe or high flow cats.
the more power the wider the gap becomes
Old Dec 9, 2003 | 06:13 PM
Larnach's Avatar
I think across the entire torque curve, hands down long tubes win. However, with the shorty's, at a higher rpm, like around 5750rpm plus, they may become a bit of an advantage.
This is a reason why Formula One engines run primary lengths of like 17"-23" or so, and they make ungodly power for being a N/A 3000cc engine, make almost 900hp.
Old Dec 9, 2003 | 06:50 PM
ZDriver96's Avatar
Larnach i dont know anything about what u posted on...
But when i switched from short tube headers to long tubes they felt the same in teh low/mid range but up top I could really feel them.
It makes sense to me that they'd flow better up top when the shorties couldnt scavenge as well.
Old Dec 9, 2003 | 07:33 PM
GreenDemon's Avatar
Actually the shorties should be better up top, while the lts should be better on the bottom, but the longtubes would be better overall just because they help out on the bottom a lot while not losing much up top (compared to shorties). I would always get lts, if space allows. Problem is it's just a pita for most people. I'll probably be getting headers soon, and I dread it. I'll probably just get the AZ S&Ms just because it says there is no engine movement required...
Since I read Car Craft like it's the bible, here's some real theory done with dyno testing if you're really interested:
http://www.carcraft.com/techarticles/116_0312_test/
Yeah, I know, I've posted that link before, but I think it's pretty good...
Old Dec 9, 2003 | 07:34 PM
GreenDemon's Avatar
To clarify, I think it would be close as far as peak power, but the LTs would give you a better powerband.
Old Dec 9, 2003 | 07:37 PM
S.J.S.'s Avatar
If you go with midlengths...shorties...go with SLP or AS&M. They are of better quality and give you the most outta that class of headers.
GREEN3112
Feb 10, 2019 09:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
