MAC Exhaust leak
Old Dec 12, 2007 | 10:25 PM
eagleknight97's Avatar
Question MAC Exhaust leak
Anyone got any nice easy ways to seal up the slip pipe on the MAC mids? Im getting a slight exhaust leak there and its slightly annoying.
Old Dec 13, 2007 | 05:55 AM
NJ-LE's Avatar
Smile
Since it's already installed things are a little more difficult, probably better to pull the driver-side header. You need to dry fit the pipe until it just barely fits by slightly closing down the end of the socket. Light, evenly spaced tapping with a soft hammer or try to reduce it with a 1.75" T-bolt clamp. You don't need to completely seat the tube, just start it. Reinstall the header. Moderately coat the the last couple of inches of the tube with Permatex "Ultra Copper" high temp RTV silicone #101BR. (This is, by far, the best high-temp silicone sealant available! It doesn't seem to affect the O2 sensors either. They claim it to be sensor safe.) Install the tube immediately. The sealer also acts as a lube so the pipe should slide right in. Tighten the T-bolt clamp and let the sealer cure overnight.
Old Dec 13, 2007 | 08:32 AM
feenix88's Avatar
I have the same headers. It was a poor design in my opinion. I went to autozone and bought a 1 5/8" band clamp, put the headers on loosely, then tightened up the band clamp and then tightened the header bolts. If you do decide to pull it and start over, be thankful its the driver side and not the passenger. good luck
Old Dec 13, 2007 | 11:33 AM
rich152's Avatar
MIG welder fix my problem fast.
RUENUF
Mar 13, 2016 03:39 PM
Midnight_Z
Feb 16, 2016 09:36 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Iamherefornow
Jan 26, 2015 04:57 PM
