M6guys, no clutch when putting into nuetral?
Old Sep 4, 2003 | 01:35 PM
94foormula's Avatar
Do you guys push the clutch in while going from gear to nuetral or do you just pull it back? Ive always used the clutch when throwing the car into nuetral but my buddy at the track said he never does.
Is it alright to not use the clutch when going to nuetral on the T56?
Old Sep 4, 2003 | 01:38 PM
cozmo's Avatar
I've always used it. But I have heard of people not. I'd assume its fine not using it, but I don't find it any easier then just pushing in the clutch. Personal preference I guess.
Old Sep 4, 2003 | 01:49 PM
gb95zconv's Avatar
I use mine....may not cause any problems if no pressure is on gear box at the time but I wouldnt make a habit of it.
Old Sep 4, 2003 | 02:07 PM
Grease's Avatar
Its okay to pull the car out of gear into neutral without using the clutch, especially at a low rpm.
Just don't ever do it with the cruise control on or you'll be in for one hell of a surprise. Try it and you'll see what I'm taking about
Old Sep 4, 2003 | 02:16 PM
jchevy's Avatar
Been there, done that. Happened in my beater acura integra.
VRRRROOOOOOOM!
Old Sep 4, 2003 | 03:31 PM
BigRich's Avatar
i don't cuz i can feel it sticking or resisting, and that can't be good
what the point
Old Sep 4, 2003 | 03:53 PM
jchevy's Avatar
If your rpms are matching the speed you are moving then it wont hurt anything.
Once you get it going in first gear you can move through the rest of them without touching the clutch. No harmfull side effects, unless maybe you force it into a gear.
Old Sep 4, 2003 | 05:01 PM
BUBBA's Avatar
Actually, you don't need the clutch for anything except 1st and reverse.
Old Sep 4, 2003 | 05:13 PM
BOWTYDE's Avatar
Sometimes I do and sometimes I don't. I don't think it is really good for the synros in the tranny.
Old Sep 4, 2003 | 05:23 PM
If you don't speed match the gears, you put excess wear on the syncros by shifting witout the clutch. IMO, there is really nothing to gain by not using the clutch-just use it.
Old Sep 4, 2003 | 06:33 PM
samdogmx's Avatar
i only use it about 50% of the time i shift & usally never when goin from a gear into netrual
Old Sep 4, 2003 | 06:44 PM
TreySpeed's Avatar
On permanent vacation
Wana explain there Bubba? I'm new to the six speed world. I thought myself how to drive just to get around, never owned a manual so im kinda confused
what ever happened gas off, clutch in, shift gears, clutch in??
DirtyDaveW
Mar 15, 2015 07:01 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
