M6er's help needed
Old May 8, 2004 | 10:15 AM
crzhrs's Avatar
M6er's help needed
When dumping the clutch at 2500 rpm's there is this thud from under the console (hard enuff that I can hear my change jingle in my cup holder) and the shifter jerks what seems to be about 3". I thought this to be a broke tranny mount, so I swapped it. But nothing changed. Still got that thump from under the car.
My car originally had an A4 and I swap in a M6. So I don't know what is considered normal for these cars.
Old May 8, 2004 | 10:33 AM
IllusionalTA's Avatar
Did you put a spacer in there ?
Old May 8, 2004 | 10:56 AM
PatriotTA's Avatar
Is everything copesetic with the torque arm? Make sure that it is securely bolted into its mount at the tailshaft of the transmission. I lost that bolt once and when I accelerated the torque arm would hit the underside of the car making a sound like you are describing.
Old May 8, 2004 | 01:25 PM
crzhrs's Avatar
Spacer? In where?
I'll check that out.
Old May 8, 2004 | 04:59 PM
Like My Taillights?'s Avatar
do you have headers? May want to check your motor mounts. Saggy mounts can cause the same condition. Good luck. -Rob
Old May 8, 2004 | 05:35 PM
Jasonz28camaro's Avatar
universial gone bad can cause bad concil pounding under a load like that.
Old May 8, 2004 | 10:28 PM
crzhrs's Avatar
Wow, is there anything that it could not be? So, is it normal for the shifter to move like that?
Old May 8, 2004 | 10:41 PM
JoeliusZ28's Avatar
id say my shifter moves a maximum of 1"
Old May 8, 2004 | 11:50 PM
zlightning's Avatar
My shifter stays put.
Old May 9, 2004 | 12:57 PM
BLB 97 Formula's Avatar
My car does kinda the same thing, I can let off the gas and then get back on the gas just a little bit and I always hear a small klunk noise (from the rear?) and my shifter moves around just a bit, figured it was normal but now I'm not so sure.
Old May 9, 2004 | 01:48 PM
carlos64030's Avatar
Sounds like a torque arm problem to me if you're sure it's not a broken tranny mount.
Old May 9, 2004 | 06:42 PM
crzhrs's Avatar
OK, now ya'll got me thinking.(Which normally is not a good thing) I have not been back under the car yet but I have a theory. Could something possible be loose or worn in the rear suspension causing the rearend to twist forcing up on the torque arm making the tranny move? Hey, that actually sounds pretty good . I might be on to something here! But what could be loose in the rear suspension causing such a problem?
Old May 9, 2004 | 07:01 PM
hsyr's Avatar
Bad U-joint or bent driveshaft could do it too, atleast it did on mine. Take off the DS and check it.
Old May 23, 2004 | 10:29 AM
crzhrs's Avatar
Update:
I have changed out the drive shaft for a ls1 shaft and installed a ES tranny mount. Still have the same problem. I'm lost someone please help me. Everytime I dump that clutch I am afraid I'm going to break something.
On a side note, that ls1 shaft smoothed out all my vibration problems.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
