M6 tranny not going into gear
Old Jun 30, 2003 | 10:49 PM
AlmostfastLT1's Avatar
I have the t56 tranny and I noticed that when I try to put into gear sometimes I cannot put it into gear. the car has 72,000 miles and has not had a clutch replaced. Could this be a pilot bearing going bad. Please let me know on advice.
PS I can hear sometimes clicking when clutch pedal is depressed don't know if it the throw out bearing.
Thanks Mark Tisdale
Old Jun 30, 2003 | 11:01 PM
96z's Avatar
96z
Is it every gear or specific gears?
Old Jul 1, 2003 | 01:08 AM
cals400ex's Avatar
will it always go into gear when the car is off? if so, it very well could be the slave/master cylinders.
Old Jul 1, 2003 | 10:05 PM
It happens when I am at a stop light and just playing the shifter and putting it into second. I will back it out of the gate and put in back into gear and it will go in.
Old Jul 3, 2003 | 01:55 AM
TTT
Old Jul 4, 2003 | 01:34 AM
cals400ex's Avatar
i am not sure what to tell you. mine does that every once in a while too. actually, since i put honda atf in there, it hasn't done it yet. i think my synchros are bad with 110K on them. i don't know if the throw out bearing can cause these problems or not. some people also had problems with a clutch spring breaking and this made the car not want to shift sometimes.
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
mattszm6
Dec 14, 2014 07:09 AM
tds1213
Nov 27, 2014 12:55 PM
