M6 guys inside...
Old Jul 28, 2003 | 05:38 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
M6 guys inside...
a buddy of mine broke his 4th gear synchro...
i think we need to replace # 3 and 4... 4th won't go in at all... and it makes a nasty metal scraping sound going into 3rd that appears like its coming from the console unless you properly double clutch it...
the transmission just got $750 worth of work, new clutch and a bunch of other ****...
my question is...
do we need to rebuild the whole damn thing? or can we just replace the 3 and 4 synchros...?
thanks
Jared
Old Jul 28, 2003 | 07:20 AM
Fastbird93's Avatar
I may be blowing smoke here, but I believe you can just replace the one synchro. However, if you're doing the one, might as well do the rest, and upgrade the shift forks ect. at the same time. Couldn't hurt, right? Well, except for the wallet maybe....
Old Jul 28, 2003 | 07:22 AM
mc63's Avatar
Why "fix" something that's not broken.
Just replace what's bad, then make sure you look everything else over for signs of wear. If in doubt with anything, replace it too.
Old Jul 28, 2003 | 08:11 AM
frmula1's Avatar
i was thinking along the lines of the domino effect... like when you fill up a tranny with burnt fluid, you gotta rebuild everything...
Old Jul 28, 2003 | 09:25 AM
96blackbeast's Avatar
preventative maintance, you shift forks will probably go out, mine have. but I would only replace synchros that are bad. they are expensive.
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
