AS&M Slip Fit Question
Old Jan 27, 2005 | 07:33 PM
RedRyder518's Avatar
Just got my AS&M headers in today. The quality looks awesome!! Anyways, how tight is the slip fit supposed to be? On mine, the primary goes in rather easily and can rotate freely. Is there anything I can do to make sure it seals up when I put them on?
Old Jan 28, 2005 | 01:05 AM
1racerdude's Avatar
Re: AS&M Slip Fit Question
When you put the supplied clamp on it ,it will be tight,put anti-sieze on joint to get it out easy again.
If clamp don't tighten it, grind the 90* tab on the end a slight ammount to make it tighter.
Old Jan 28, 2005 | 10:08 AM
I bought them used so I don't have the supplied clamp. Would it just be a regular U clamp like used on slip fit exhaust systems? How about like a band clamp?
Also, does anyone know offhand what size fitting I will need for the '96 AIR to work on a '94/'95 AIR fitting?
Old Jan 28, 2005 | 12:17 PM
1racerdude's Avatar
Call AS&M and get the stuff you need. They are in Arizona and have what you need on hand.
It is not a regular clamp.
Old Jan 29, 2005 | 04:10 PM
marshall93z's Avatar
i installed mine with no clamp, and they have NEVER leaked! im very surprised but this too...
and the fit was loose as hell too!
Old Jan 29, 2005 | 04:17 PM
And when you say loose fit, do you mean it can wiggle around, and basically turn freely?
Old Jan 29, 2005 | 07:01 PM
RE AND CHERYL's Avatar
Mine didn't have any clamp. The fit was actually quite snug and I had a time getting it in all the way. Never leaked a bit.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 23, 2015 01:13 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
