AS&M 58mm Tb - Offset and Idle ????'s
Old Mar 21, 2005 | 01:35 AM
sweetride45's Avatar
AS&M 58mm TB offset??
Is the AS&M 58mm TB offset at "0" (ie, on center w/ the stock bore)? I heard the only one that is "off center" is the 54mm ones. I'm going to bore out my intake, and I don't have the tb yet....I was planning to just go off center to 58mm...
Old Mar 21, 2005 | 06:45 AM
slverbullet's Avatar
Re: AS&M 58mm TB offset??
i dont think it is off center. at least i hope not! i'd almost think at 58mm it would be too big to be off center. ill let you know in a few hours for sure though. my intake should be coming back to me today after being ported.
Old Mar 21, 2005 | 08:58 AM
Yeah, I wouldn't think it'd be off center either. I don't know why'd they do it like that. Hopefully it wasn't the 58's.
Can anyone verify?
Old Mar 21, 2005 | 10:15 AM
91RSLT1's Avatar
Don't guess, wait till the TB get there, and then use the gasket as your template. That is the best way to do it. It will cut out all the guess work.
Old Mar 21, 2005 | 10:21 AM
I just wanted to know if anyone knows the answer offhand, that has the 58mm AS&M...
Old Mar 21, 2005 | 01:05 PM
What's the idle issue that I've read some have w/ this TB too? Anything to be concerned about?
Old Mar 21, 2005 | 02:51 PM
Someone has to know what I'm talking about! lol
I'm sure someone has this TB
Old Mar 21, 2005 | 08:42 PM
Asm 58mm Tb
Seems as though my other thread got ignored, so, my question is....Is there some type of Idle issue w/ this TB? I've searched and read a few that said there is such a thing...not sure what it's composed of, or if it's an easy fix...
Old Mar 22, 2005 | 12:25 AM
okay, i got my as&m 58mm on tonight. no it is not offset. as far as the idle issue goes, i assume you are talking about the split blm problem?
listed here: http://para.noid.org/%7Elj/PCM%20Tut...litBLMinfo.htm
Old Mar 22, 2005 | 12:33 AM
Not sure if that's it or not. I just heard it had a rough idle, or would not idle...I've done some research, and come up w/ slotting the TPS and adjusting the idle stop screw, b/c it's not right from factory...
So, the split BLM's are a problem as well w/ this tb?
Old Mar 22, 2005 | 12:38 AM
ah yeah, that too. i have yet to mess around with it any. but the instructions to the tb do mention that as well. i had forgotten about it until you mentioned it. i got the TB about two months ago and read about that then and forgot about it. ill have to look into that more. kinda retarded problems considering the cost of these thing!
Old Mar 22, 2005 | 12:40 AM
I really don't feel like making some Brass fitting like that link suggests, and doing that stuff to a $500 piece, lol...I suppose it's no big deal, but would rather not *** around
Old Mar 22, 2005 | 07:06 AM
Dave88LX's Avatar
Just use your gasket for your template on what to shave. Here is what I had to cut out of my intake. Not offset at all.
http://paradox.shacknet.nu/dave88lx/...8mm-gasket.jpg
Old Mar 22, 2005 | 07:09 AM
Dave88LX's Avatar
TB:
http://paradox.shacknet.nu/dave88lx/...rottlebody.jpg
Old Mar 22, 2005 | 08:52 AM
Dave: Any idle issues? Any split BLM's? Did you have to do the brass fitting thing, from the link shown above?
