ltcc help needed
ltcc help needed
ok i've tried many different combos on this with no possitive prevail......i dont know if there is a big diff in the wiring scimatics through out the years but i tracked down one for i believe a 95 and here is what i found\
pin mine says labled harness to coil
g red coil 2 g 1
h green coil 4 h 3
j blue coil 6 j 5
k purple coil 8 k 7
m red/white coil 7 l 8
n green/white coil 5 m 6
p blue/white coil3 n 4
r purple/white coil 1 p 2
i tried switching all harnesses so the worked with the wiring diagram i found and it will run for about 5 seconds stall and blink 2 and then 3
with the way i had it set up originally it would run but eventually start missing but i had no trouble codes just green light
does this give you any idea...is this possible the wrong one for my 96 or a problem with the black box
i'm at dead end here figuring things out....anyones input would be great....perticularly if you have a ltcc setup on a 96 and could look at your wiring for me
each coil has 4 wires at the harness pink brown black and which ever color goes from the black box listed above
g red coil 2 g 1
h green coil 4 h 3
j blue coil 6 j 5
k purple coil 8 k 7
