Lt4's worth it ?
Lt4's worth it ?
Look likes I am not lucky! I just installed the hotcam kit and BBK shorties
this year and now the car is sitting in my driveway with a rod knock sound
I didn't even run it hard!
But right now I can have a good deal on an 96 LT4 block and head for 1500 $ CAN is the lt4 bottom end is really better than the lt1 ?
or is it better to splaye the lt1 and probably buy a stroker kit!?
thanks for your awnser
I didn't even run it hard! But right now I can have a good deal on an 96 LT4 block and head for 1500 $ CAN is the lt4 bottom end is really better than the lt1 ?
Hmm, if you look around you can find entire LT4 engines with the accessories and wiring and PCM, full drop in for about $3k-3500k, so I'd say $1500 for just the bare block / rotating assembly and heads is not worth it unless its sitting brand new in the create.
mark0006
Aug 29, 2015 09:45 AM
