lt4 valve springs??
Old May 13, 2004 | 10:56 PM
Got-LT1's Avatar
lt4 valve springs??
A. Where can you get them?
B. What else do I need to install them?
Did a search and didn't find anything.
Old May 13, 2004 | 11:00 PM
97WS6SCharged's Avatar
You can pick up the springs at www.sdpc2000.com
You will need a valve spring compressor, something to hold the vavles closed (air tool), as well as the locks and retainers. A new set of valve seals might not be a bad idea as well. I think that's everything.
Old May 14, 2004 | 12:20 AM
Bud M's Avatar
12495492 Valve Spring Cap Kit, LT4
This valve spring cap kit which includes 16 of P/N 10212808 caps, is used on all 5.7L LT4 engines. These are light weight caps to be used with valve spring kit P/N 12495494, and key kit P/N 12495503. _
from http://www.gmpartsdirect.com
I used the KD Tools spring compressor with the removeable handle.
You can remove the springs without pressurizing the cylinder if you bring the piston to tdc.
Old May 14, 2004 | 01:00 PM
Got-LT1's Avatar
I am going to have the heads of anyway so I don't need to worry about air compressor or anything...
Thanks for the help though.
Old May 14, 2004 | 01:26 PM
95Bird's Avatar
I have valves, springs, retainers, locks etc. from lt4 heads never used if your interested.
Old May 14, 2004 | 01:43 PM
gb95zconv's Avatar
The stock retainer and locks will work with the lt4 springs. The whole set of springs is like $38 @ paceparts
http://www.paceparts.com/product.asp?3=905
nikolt1
Feb 27, 2015 09:10 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
