LT4 Valve Covers w/ Traction Control?
Old Mar 1, 2006 | 08:51 AM
ArizonaZ's Avatar
Is it possible to install LT4 valve covers if you have traction control. As far as I know, this is the 6"x6" box above the drivers side valve cover, but sits very close to it. I don't know what the height difference is between the two covers, but it looks like it would be real close.
If it won't work in is current position, can the traction control be removed or relocated easily?
Any thoughts?
Old Mar 1, 2006 | 01:14 PM
ArizonaZ's Avatar
Re: LT4 Valve Covers w/ Traction Control?
Nobody's tried this before?
Someone out there has to know something.
Old Mar 1, 2006 | 02:43 PM
eagleknight97's Avatar
Ive attempted to find an answer about moving traction control myself many times over the 3 years ive been a member, and have never sucessfully gotten an answer. Im sure its entirely possible, and if you had the time and know how, im sure you could do it rather easily, however I have neither of those really so I was looking for a sure fire way to do it and couldnt find one. Ive often thought of trying to mount it somewhere near where its mounted on LS1's, but am unsure of how to lenghten and route the throttle cables. Hopefully you find something and if you do, let me know, cuz I like ASR in certain situations, but it makes the engine look real ugly.
Old Mar 2, 2006 | 02:34 AM
Actually thinking a lil more about this, would it be possible to simply use LS1 throttle cables for engines with ASR? Wouldnt that work if I were to somehow mount the ASR motor in that area somehow?Hmmmmmm
Jlo
Feb 3, 2015 09:41 PM
ModdedNerd
Jan 29, 2015 07:23 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
