LT4 Valve covers and Comp 1.6 RR Grind or no grind?
I put the valve cover on the heads with out grinding out any supports. I have not bolted them down, just placed them over the RR till they sat on the head. I don't have a lot of room to slide the cover from side to side or forward and back.
I have seen the post on grinding the supports out but I am wondering if I need to or not since they don't seam to be bottoming out on anything. I don't want to grind tham down if it is not needed. Has anyone else had this happen to them recently? I don't know wether or not I shold grind them?
I went to ace and got some washers but Im still not getting a tight seal around the cover. I bought 1/4 by 1 inch washes and I probably should of got the washer to fit over the stud to make it work the way I need it to.
No I have to have a threar repaired because the stupid hole was to shallow and I tightend it enought to mess up a threar or to at the bottom. I'm wondering how hard it would be to drill and tap the hole for the correct lenght? Any one know?
Speeds8erM-1
Jul 18, 2002 11:36 PM
