lt4 valve cover clearance??
Old Sep 3, 2007 | 04:57 PM
Irish350's Avatar
okay, so i got some lt4 valve covers so that theyll clear my 1.6 RRs... and i go to put them on, and they dotn even come close.. there still like 1/4 inch between the gasket and the head.. i looked on the inside and it looks like there are braces for the stock lt4 style rockers, so do i have to cut those off?
hook a brotha up with some info?
Old Sep 3, 2007 | 06:36 PM
Irish350's Avatar
cmon.. i know there are some lurkers here that have these covers.. dont make me join naisso to get some answers
Old Sep 3, 2007 | 08:56 PM
You left out what rockers you are using. cmon, don't make us have to pry it out of you.
My Comp Pro Mags and LT4 covers work fine.
Old Sep 3, 2007 | 10:44 PM
SS RRR's Avatar
How tall are the adjusting nuts? Take pics if possible. I doubt it's the width of the rockers holding you up.
Old Sep 4, 2007 | 06:51 AM
SnakeOiler's Avatar
Correct, if you are using long style poly locks, you definitely could have some interference. Make sure you have short style poly locks.
Old Sep 4, 2007 | 12:38 PM
Irish350's Avatar
whats the difference between poly locks and... whatever the alternative is..?
haha
theyre RKE 1.6s on a 7/16 stud..
this is the best picture i have ATM
Old Sep 4, 2007 | 01:55 PM
JAKEJR's Avatar
When recently building my 388 LT1 for my 96 Vette using Scorpion 1.7RRs and tall poly-locks, I had cover clearance problems too. Covers wouldn't sit flush with the head and I had the same gap as you mentioned. The underside of the covers were siting on the polylocks preventing them from dropping down flush.
I went with 1/4" taller covers from SummitRacing, but had to mod the baffles in them to clear a rocker on each head. Covers ran about $150 and are GM licensed.
I also had to grind a small area on the alternator to clear the taller cover.
Jake
Old Sep 4, 2007 | 06:37 PM
Irish350's Avatar
but i was pretty set on using these valve covers.. i just got in the studs (or at least what i think are the studs that i need) and the pcv that i needed for the lt4s.. no one had this problem and kept the lt4s??
Old Sep 4, 2007 | 07:06 PM
Mikey97Z's Avatar
No problems here with the LT4s. Just buy the shorter poly locks from comp cams and you're set.
Old Sep 4, 2007 | 07:09 PM
Irish350's Avatar
at this point in time id rather just cut off the little nubs on the underside of the VC... any problems with that?
i wont do it if theyre there for some reason, but i cant find any so far..
Old Sep 4, 2007 | 07:47 PM
Mr_Bond's Avatar
If the valve cover are not from a 96 vette, you have to clearance the composite valve cover for roller rockers. I did a 1994 vette, and the valve cover had to be clearanced. The ones I got from a 96 vette fit on with no problems.
Old Sep 4, 2007 | 08:08 PM
MEAN LT1's Avatar
Hows the setup coming out man, is it running yet?
Old Sep 4, 2007 | 10:38 PM
Irish350's Avatar
okay.. im pulling out the dremel and cutting off these things.
Old Sep 4, 2007 | 11:53 PM
Irish350's Avatar
...turns out it was that the studs werent going INTO the gaskets... cause apparently theyre supposed to do that.. ah well, now theres plenty of room. haha
Old Sep 13, 2007 | 02:07 PM
Mr_Bond's Avatar
The A$$ dyno and the 508 hp Cobra I put bus lenghts on NA, says its running good. I need to get it to the track\dyno to get some official numbers.
Irish350 heres's some pics of the of the tab ground off the cover on a 95 vette
