LT4 timing set noise or worse???
Recently I did a heads/cam swap and installed a GM LT4 heavy duty timing set. Ever since I finished the mods after the engine heats up, it sounds kind of like I'm running a gear drive. Using a long blade screwdriver to listen, the majority of the noise comes from the opti. Couldn't hear it through the water pump or the timing cover. Since the original opti bearings were questionable , I figured that it was the opti bearings making noise and replaced it. I installed an electric water pump at the same time. After replacing the opti and pump, the noise is still present at the same volume. As was before if you raise the RPM by 100-200, the noise settles out and everything sounds nice and smoothe (even listening to the opti with the screwdriver). The question is, are the Lt4 hd sets noisy, am I getting ready to grind up the water pump drive gear (which is useless now), any other ideas??
Thanks Everyone
Thanks Everyone
I checked min very closely to ensure that the gears did not bind.
Thanks all
When listening with the good old screwdriver, it DEFINITELY sounds like gear noise. I'm going to go ahead and pull out the water pump drive gear. Since I don't need it, it won't matter anyways. I just have to find something o plug the timing cover with.
