Lt4 question??
Old May 8, 2003 | 01:03 PM
godbk's Avatar
Lt4 question??
Whats the diffrence between the LT1 Block and the LT4 block? I have a 94 LT1 camaro and i want to do the LT4 conversion but don't have enough money what parts would i need to buy to do the conversion the LT4 intake, Heads and a LT4 hot cam what other stuff would i need like push rods rockers springs and whats a good website to get this stuff from?
Old May 8, 2003 | 03:09 PM
godbk's Avatar
any one?
Old May 8, 2003 | 03:13 PM
1997rblckSS's Avatar
this should give you some direction..
http://corvetteactioncenter.com/specs/1996/lt1lt4.html
its just a comparison, but it has all the specs I think you are looking for...
Old May 8, 2003 | 03:14 PM
turbo_Z's Avatar
the LT1 block has 2 bolt mains.. the LT4 has 4 bolt mains
you can get all of the parts from GM parts direct if you want a good price otherwise www.tbyrnemotorsports.com has the whole LT4 package listed in the LT1 section of their page.
Old May 8, 2003 | 03:59 PM
BitCypher's Avatar
Jason Cromer with Sam Taylor Buick in Ft. Walton Beach, FL is the CHEAPEST place to get the necessary parts. I know of a few people that have gotten the entire LT4 conversion kit (LT4 HotCam kit, LT4 intake, assembled LT4 heads, and the extreme duty timing chain kit) from him for something like $2200 (if you're in FL, you'll have tax on that).
Click here for the Sam Taylor website
BTW, I know of one individual that did the LT4 conversion on a '96 Z28 and along with Hooker LTs, Mufflex Y-pipe, and PCM programming his car pulled 380rwhp. Everyone called him a lair, but I've dyno'd with him and seen his numbers....Here's his dyno page: http://www.imaliar.net
Old May 9, 2003 | 08:10 PM
arnie's Avatar
Unfortunately, that is a misleading answer. I can easily say there is no difference between the two.
B-body and F-body LT1 blocks are 2 bolt main. Vette LT1 blocks are 4 bolt main. There is no specific LT4 block. The LT4 engine used the same LT1 vette block. So yes, the LT4 engine has 4 bolt mains.
LeftoverChinese
Jan 14, 2024 03:03 PM
pimpss96
Feb 12, 2015 01:28 PM
ModdedNerd
Jan 29, 2015 07:23 PM
WildRidez
Jan 16, 2015 03:10 PM
95chwagon
Jan 13, 2015 09:19 PM
