LT4 or ported Iron heads for a 383
Old Oct 14, 2003 | 10:28 PM
  #16
NightTrain66's Avatar
I would recommend the LT4's as well.
I would use some of those CM 612 springs and if you decide to use a larger cam later on (GM 847, etc) get some Dbl springs at that time. If you are not going with a larger cam, the CM 612's will last forever.
The cc305 will seem VERY sm,all in the 383 but if that is what you want or have budgeted, so be it.
NightTrain66
Old Oct 14, 2003 | 10:37 PM
  #17
Ai's Avatar
Ai
Isky also has a decent little spring, the 235-D. It's probably pretty similar to the others mentioned.
Old Oct 14, 2003 | 11:05 PM
  #18
Phil, long time no hear.
The CM 612's re $80 from Combination Motorsport and that is for springs, retainers and locks. About 130 lbs on the seat and well over 300 lbs open (.600) and a great price. They can handle quite a bit of lift as well.
Hard to beat for the $$$.
NightTrain66
Old Oct 15, 2003 | 04:40 AM
  #19
grygst76's Avatar
go with the comp 986-16's. they work with the 305 grind and if you want to upgrade to a 306 it will work with that one too
Old Oct 15, 2003 | 04:49 AM
  #20
HM Murdock's Avatar
I have the Crane 10308's and they work great with my 306 setup...And I'd get the LT4's...huge weight savings...
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
