LT4 intake
Old Dec 31, 2003 | 04:49 AM
  #16
Wild1's Avatar
2nd Nitrous. I like the new NX Maximizer progressive. It works cleanly with a Palm and fully programmable. I downloaded a test copy and it is very slick! You shouldn't hurt anything with a 100 - 150 shot.
Old Dec 31, 2003 | 12:52 PM
  #17
DrewHMS97SS's Avatar
the maximizer is bad ***, but if you can afford it (529 for just the controller) use a window switch, retard box, and WOT switch.
Old Dec 31, 2003 | 02:23 PM
  #18
Wild1's Avatar
It is a trick system But it is a bit pricey. It has a built in window switch, retard, wot switch, relay which would add up to under $200 if bought separately. Wait a few paychecks and get the Maximizer. I'll get the O2 Extension as I don't want to solder and heat shrink into my original harness. I've got the RPMs available through my Jacobs system... no need to splice there.
I'm about one month away from the whole system.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
