LT4 heads w/ cc305
Old Jul 5, 2003 | 09:29 AM
Zjoker's Avatar
LT4 heads w/ cc305
Is it possible to run this combination and if so what are the down falls to it ?Getting ready to get heads and cam.
Old Jul 5, 2003 | 09:46 AM
gb95zconv's Avatar
I guess you have the lt4 intake also to go with those heads. Anyway.....I would go with one of the XE grinds 224/230 or even a 230/236. I would also suggests atleast getting the heads cleaned up and matched.
Old Jul 5, 2003 | 10:46 AM
Josh-'04 GTO's Avatar
Re: LT4 heads w/ cc305
That combo would work fine, should be able to knock down 370-390 rwhp with a decent tune without a problem.
Old Jul 5, 2003 | 03:29 PM
SS MPSTR's Avatar
Re: Re: LT4 heads w/ cc305
Were you referring to the CC305 or the other cam mentioned? If it was the CC305, then I should have you tune my car for me.
Old Jul 5, 2003 | 05:19 PM
Zjoker's Avatar
Talking
Thanx guys. a King is Born
Old Jul 5, 2003 | 08:23 PM
Re: Re: Re: LT4 heads w/ cc305
The CC305. Expect the lower figure if you're still running a 350, and the higher number if you're running a stroker. It's not a huge cam for a stroker by any stretch, but will make great emissions legal power. That also assumes you have no problems, have a good intake/exhaust setup and are running good compression(11.0-12.0).
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
