Lt4 heads
Old Dec 25, 2003 | 10:53 AM
1984camaroz28's Avatar
Lt4 heads
will Lt4 heads bolt on to a LT1 block and if i use Lt4 heads i need an LT1 intake
Old Dec 25, 2003 | 11:09 AM
$hawn's Avatar
Yes they'll bolt on, just need the lt4 intake as well.
Old Dec 25, 2003 | 12:32 PM
dragon93308's Avatar
will an lt-4 intake fit on stock heads?
Old Dec 25, 2003 | 12:56 PM
Dan946spd's Avatar
No, I do not believe a LT4 intake will bolt to LT1 heads. Different size ports.
Dan
Old Dec 25, 2003 | 01:14 PM
Kryckter's Avatar
I understand that the differance between lt-1 heads and lt-4 intake and so forth would be the angles of the suface. Such as the lt-4 intake wont match lt-1 heads cause the angle where they meet is different. That is what i understand. Someone correct me if im wrong!
Old Dec 26, 2003 | 07:05 AM
arnie's Avatar
You're wrong! Not one answer given in this thread is without errors or misleading info. This subject has been 'straightened out' to redundant excess. Do a search here, as well as in the 'advanced tech' section.
Should/could include in search, posts by 'arnie'.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
