Lt4 heads??`
Lt4 heads??`
Im getting a cc306 cam for my 94 but i dont know about the heads. I hate to spend an arm and a leg due to the fact im still in college. I saw the lt4 heads are 1200 from gm partsdirect. Is that a good deal for those heads? would that be a good setup with my cam??? Thanks!
The LT4 heads are a low budget way to get the extra HP. You will need the LT4 intake. With the raised intake ports,larger and lighter valves for $1200 isn't to bad a deal.
Someday maybe get them ported and they will be hard to beat.
Gordon
http://www.witchhunter.com
Fuel Injector Cleaning & Flow Testing
Gordon
No offense, but why spend $1200 on a set of stock LT4 heads that you aren't going to port? You will most likely make 380ish rwhp with those heads and that cam, If you went to the AI heads (stock casting) for just a little more, you can hit near or over 400rwhp? For the same price you can easily get more power. If you are going to have a good porter work on the LT4s its a different story, but from the sounds of it you will leave them stock.
Chris
Chris
ok wait a minute guys...i think your going to have to do some explaining to me...so with just heads and a cam, hes going to be making 350-400 hp???? there has gotta be something elese done to the car right? sorry this might sound stupid but im lost
thanks guys
thanks guys
yes i do have all the bolt ons! and what i am looking for is about 380 rwhp. it is my daily driver for now. But, as soon as i get a reliable car to drive. I will port and polish the heads for better hp! So getting these heads wouldnt be a bad idea if a low 12 second car is what im looking for right now???
I wouldnt advise getting the LT4 heads unless you either keep them stock or just go with a mild porting...considering the raised runners on them they'd work better with an engine with more than 350ci's...
95chwagon
Jan 13, 2015 09:19 PM
Deals are out there
