LT4 Fuel Rail Bolts Different
Old Jun 22, 2007 | 08:43 PM
Fastbird93's Avatar
Went to hook up my happy hooker to my LT4 manifold on the new motor tonight, and the bolt holes for the fuel rails on the LT4 manifold are MUCH smaller than the LT1 manifolds that I have. What gives, anyone seen this?
Old Jun 22, 2007 | 09:22 PM
Fastbird93's Avatar
Trust me, these aren't. They are WAY smaller than the bolts that I just took out of my motor that's still in the car.
Old Jun 22, 2007 | 09:31 PM
Fastbird93's Avatar
I just found a spec -- M6 x 1 x 35. Weird though......both of the 93 manifolds i have sitting here are more like a 10mm bolt.
Old Jun 22, 2007 | 10:34 PM
Kevin Blown 95 TA's Avatar
Maybe it's just the 93 that's different - I used all the '95 LT1 hardware on my LT4 manifold.
Old Jun 22, 2007 | 11:01 PM
Javier97Z28's Avatar
Moderator
The happy hooker bolts to those tiny intake manifold bolt holes and bolts? Holy crap I'd be scared to use that....
Old Jun 22, 2007 | 11:06 PM
No kidding!!! I did use them though and they hold just fine. However I had a 2" nylon strap double wrapped around it in case it didn't. I guess the total tensile strength on those 4 little bolts is enough to do the job if they are all secure and the threads are healthy. Honestly, I had to do a real gutcheck when I lifted it off the stand that way - I tested it real carefully.
Old Jun 23, 2007 | 04:16 AM
1racerdude's Avatar
That's what I said on the first use.
Old Jun 23, 2007 | 07:56 AM
So, have you used it a few times just like that?
Old Jun 23, 2007 | 03:32 PM
1racerdude's Avatar
Yes
Old Jun 23, 2007 | 05:42 PM
Fastbird93's Avatar
Ok, looks like the answer popped up. Apparently the 93's were M8x1x35 and 94+ were M6x1x35. Weird. 93's got all the good stuff!
Old Jun 24, 2007 | 01:27 AM
JAKEJR's Avatar
I KNOW THE FEELING! I installed my new 388 this afternoon and even with the heavy chain I was using I held my breath.
Jake
HectorM52
Jul 30, 2017 11:46 AM
4586
Feb 13, 2015 09:16 AM
rcajun86
Jan 30, 2015 01:56 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
