lt4 corvette camshaft
Old Aug 20, 2007 | 01:24 PM
IPISSONFORDS's Avatar
I was wondering if I could just take a lt4 corvette camshaft and swap it out with my stock lt1 camshaft without doing any other conversions. Info on my car is in my sig.
Old Aug 20, 2007 | 01:39 PM
'94 Bad A Z28's Avatar
The production LT4 cam is not as big as the LT4 Hot cam so depending on mileage on the car your stock valve springs should be okay, but I would NEVER suggest reusing stock valve springs. I wouldn't even reuse aftermarket valve springs unless they were very low milage, especially going to a bigger cam.
Old Aug 20, 2007 | 01:40 PM
In other words yes, but as a safety precaution I would also change out your valve springs.
Old Aug 20, 2007 | 01:47 PM
Thanks man!!!
Old Aug 20, 2007 | 02:10 PM
LiENUS's Avatar
No, you'd need a new timing set and new timing cover as well (93 comes with non-vented 96 was vented)
Old Aug 20, 2007 | 02:27 PM
zx1216's Avatar
don't bother, do a search and look around some more and you'll see why...
speed_demon24's Avatar
There's no point in doing that since they are basically the same size.
Old Aug 20, 2007 | 02:28 PM
Compstall's Avatar
No he wouldn't, it's a standard roller cam. The only thing that might need to be modified is the dowel pin to the opti.
Old Aug 20, 2007 | 02:38 PM
LiENUS's Avatar
You're right just took a look at the pictures of the cams
The one on the left == vented right == unvented. The leftl'l work in place of the right one as long as the dowel pin is modified. Though theres not a lot to gain by going to the LT4 camshaft, the LT4 was more than just a camshaft, it was new set of heads and different rockers as well.
The cam specs are here
Not a lot more duration there and the lift advantage you'd get most of that just putting in 1.6:1 rockers.
Old Aug 20, 2007 | 02:39 PM
Stl94LT1's Avatar
Installing a stock LT4 camshaft in an LT1 is a waste of time. Use some 1.6 roller rockers with your LT1 camshaft and it will be close to the stock LT4 cam.
Old Aug 20, 2007 | 05:50 PM
Compstall's Avatar
I was going to mention the waste of time part. At least scrounge around and find a good used Hotcam for ~$100 if you're going to spend the time.
Old Aug 20, 2007 | 06:10 PM
2000GTP's Avatar
Considering the cost of just a replacement gasket set and other materials, along with the invested labor, I would definitely look into the Hotcam or better. With the Hotcam, you can pretty much get away with everything aside from a valve spring change.
Old Aug 20, 2007 | 06:14 PM
Heatmaker's Avatar
Advanced Member
I'll be very honest with you.
For the time and work involved, I wouldn't do it for a cam with such meager performance.
If your trying to do major mods on a budget,a cam swap ins't one of them. It's better to have fresh parts when you do a job of that severity.
Old Aug 20, 2007 | 06:23 PM
wrd1972's Avatar
Get a bigger cam, the "LT4 cam" might provide teeny tiny HP increase over the stock LT1 cam. The LT4 hot cam is another story.
Old Aug 20, 2007 | 07:20 PM
Thanks for the input guys there is a guy on craigs list selling a LT4 camshaft from a corvette for $200 but I was wondering if I should do it or not.
