lt4 conversion questions
Old Aug 11, 2003 | 03:28 PM
  #16
94formulabz's Avatar
I think he was assuming you had a good 60' time for your 12.9 run. Notice his sig as well.
Old Aug 11, 2003 | 05:06 PM
  #17
kaoticcamaross's Avatar
oh ok well I had a 1.98 60 ft time.
Old Aug 13, 2003 | 01:00 PM
  #18
sleeperz28's Avatar
I've never seen an LT4 corvette go mid 12's. The LT4 corvettes are rated at 330 HP. So why would you make much more? The heads arn't going to flow as much as ported lt1's. Im guessing low 13's with the LT4 and most port head lt1's with cam go high 12's.
Old Aug 13, 2003 | 01:11 PM
  #19
i've never dyno'd an LT4 vette, but they were supposedly conservatively rated.
Everyone talking aobut the LT4 conversion is using the LT4 HOTcam, not production cam, thats a huge difference.
You should easily be able to go low 13s in decent weather with a stock head/cam car unless your at altitude, so thats a lil off.
Old Aug 13, 2003 | 09:22 PM
  #20
92LT1RS's Avatar
I have a '92 RS that I swapped a '95 LT1 into. About a year later I swapped LT4 heads and Hotcam and 1.6 rockers into it. I got a pcmforless.com program, stock LT1 throttlebody and injectors, Heddman headers, and 3.42 gears out back. So far the best I've run was a 13.1 @ 109 with a 2.0 60' on street tires. Still wondering why my mph is so high but the ET isnt there. Looking back, I wish I would have gotten the LT1's ported and gotten a bigger cam to begin with but oh well, you live and you learn.
The LT4 conversion is a great mod, but it just depends on what your goals are for the car. If you want a fun to drive, fairly hot daily driver, go for it. But if you have any thoughts of going faster and bigger later on, then you may want to look into other options.
Old Aug 13, 2003 | 09:25 PM
  #21
hotazzz28's Avatar
test
Old Aug 23, 2003 | 09:48 PM
  #22
Hotwire's Avatar
Well, wouldn't a rock solid LT4 conversion be a better bet for performance, and a better foundation on down the road for more performance versus an LT1?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
