Lt4 conversion in car?
Old May 30, 2005 | 02:03 PM
fndmntlsofpimpn's Avatar
How hard would it be to do a full lt4 kit with the motor in the car? is it even possible? also would it require a dyno tune in an automatic?
Thanks,
Kevin
Old May 30, 2005 | 02:28 PM
AsianSensation's Avatar
Re: Lt4 conversion in car?
It has been done thousands of time, so it's possible. The difficult level is the same as any cam/head swap. Better get a tune, dyno tune is even better.
Old May 30, 2005 | 02:38 PM
LT4Z28's Avatar
It is very possible to install an LT4 conversion on an LT1 while in the car. As a matter of fact, I just finished buttoning up the one in my 96 Z28. The only thing you have to do is move your condensor up and out of the way to get the cam in and out. Other than that it can be done. Also the angle torquing of the heads is kind of tricky. As far as tuning, the car will fire and run but you won't get max performance w/o custom tuning .
LeftoverChinese
Jan 14, 2024 03:03 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
