lt4 afr 220 what spark plugs ??
Old Apr 17, 2004 | 07:11 AM
BIGCOWL-IMP's Avatar
just putting my 396 together and i`m wounding wicth spark plugs to use its a 95 lt1 396ci with lt4 220 afr heads and i will be useing a 150 shot
if you need more info let me no
Old Apr 18, 2004 | 08:03 AM
anybody ???
Old Apr 18, 2004 | 01:24 PM
Hoostie's Avatar
The dude at afr told me to run ac delco 41-629.
Old Apr 18, 2004 | 01:41 PM
SSideways's Avatar
try looking at AFR's
under the head that you have it usually state's what spark plug you should start with. It's under the Specifications, Features, and Supporting Components
Old Apr 18, 2004 | 09:35 PM
Hoostie you going to be useing spay ?? Have you ran them yet ??
Old Apr 18, 2004 | 10:21 PM
Joes94TA's Avatar
AR3910 ..its a gasket race plug should be colder also
Old Apr 20, 2004 | 06:10 AM
thanks for the info Joe you have a pm
Old Apr 20, 2004 | 10:29 PM
SSideways's Avatar
WOW!!! BIGCOWL-IMP
I see you would rather take Joe's word instead of AFR's website which says to use the AR3910, Nah just playing with ya!!!
hope it works out for you cause I've been trying all types of plugs. the latest is the rapid fire #5 which seem to work OK for now, I've also used NGK's and AC delco's (fr3ls,fr4ls) and will soon be trying the Autolite AR3910's.
Old Apr 21, 2004 | 01:31 PM
SILVERZZ28's Avatar
Can you plugs guys fill me in on the heat ranges?
Is this the correct order?
coldest to hottest 3934, 3933
3932, 3911
3910, 3924
3923, 3922
5184
If so I was told by AFR to run the 3922s with a 12.1:1 LT1 and go to a 3924 if it does not ping
Old Apr 21, 2004 | 11:36 PM
SILVERZZ28's Avatar
Actually after doing some research the 104s are the same length. why not use those?
Old Apr 22, 2004 | 09:50 AM
SILVERZZ28's Avatar
Did I kill this thread
Old Apr 29, 2004 | 09:15 PM
yep its dead
Old Jun 7, 2004 | 09:05 AM
o.k. just picked up a set of AR3910
what should the gap be at ??
yes i have msd
Old Jun 7, 2004 | 10:07 AM
EddieP's Avatar
104's are a taper seal type spark plug, and shouldn't be used unless you cut the taper into the head (AFR uses a gasket style plug).
Old Jun 7, 2004 | 11:13 AM
4drLT4's Avatar
yes i have msd
I'm currently running a .035 gap with mine. I'm running a Dig-6 ignition box. Runs nice and smooth, no shortage of power.
