LT1's and premium gas
Old Jul 29, 2006 | 08:42 PM
Camm95Z28's Avatar
This little irratation has been going on for almost a year now. The guys I work with ask why in my 95 Z28 I run the " high test " as they call it. I attempt to tell them about the 10.5 to 1 compression ration and that the manual calls for it. They retort with that it's not necessary, they're v8 runs just fine on regular gas as they point to such hot rods as they're F-150.
I knowmy brother ran middle grade in his LS 1 Z, but does the LT1 need premium?? Thanks for reading
Old Jul 29, 2006 | 08:50 PM
JimboManJones's Avatar
Re: LT1's and premium gas
91 and up. You can run lower grade, and it retards the timing, so it doesn't ping and knock and you won't end up damaging the motor. Tell them that with the 91 octane you run more timing which makes it faster then their pos boat anchor v8 in their ugly ford.
So if you want to run lower grade, your car will be fine, it'll just be a tad slower.
This is the way I understand it, someone correct me if I am wrong.
Old Jul 29, 2006 | 08:51 PM
69z-28's Avatar
does any engine NEED higher octane. no not at all, but running lower grade fuel will result in less performance and detonation and pinging noises. it is not smart to be cheap with gas on LT1s because the high compression like you said and basically the engine was built to run on a minimum amount of octane. can u get away with less, yes, is it smart, not really.
Old Jul 29, 2006 | 09:14 PM
BMWKillR's Avatar
From what i have heard, the compression ratio is too high for anything under 91, at least to perform to maximum capability. Those F-150 engines are lower compression and also are not exactly "performance" oriented. They prolly have good lowend torque...especially if they were diesel, but they are built to haul things around not go fast. Also, ask them what their redline RPM is...i bet its a lot lower than yours.
Old Jul 29, 2006 | 09:24 PM
SS RRR's Avatar
If the LT1 only required premium it would say on the inside of the gas cap lid like the LT4. Because the LT1 knock module is more sensitive lower octane gas can be used without harming the engine. If you have a LT4KM in the PCM then run premium only.
Old Jul 29, 2006 | 10:18 PM
96capricemgr's Avatar
It is not the compression that causes the 91 octane minimum recommendation. It is the tuning. The b-body LT1 was 10:1 with iron heads and tuned for 87, "conventional wisdom" says you can run a full point more compression with aluminum heads. Yes the LT1 is fairly high compression but with the cooling it has is not that octane sensitive.
When my motor was cam only I ran it on 87 because I tried a 87 octane tune for winter one year and noticed zero drop in performance. The current setup is more like 11.5:1 though so I feed her 93, checked cranking compression today and it was 230psi. The same "conventional wisdom" that says aluminum allows a full point more compression without detonation says 180-190 is MAX for pump gas, technology has rewritten a lot of the old rules.
Old Jul 30, 2006 | 11:18 AM
Simply show the doubters your Owner's Manual, that indicates you may lose performance if you use low octane fuel. My Ford F-150 (Triton V8) manual specifically says it requires only "regular" unleaded, and the performance is nothing to rave about.
A question.... why would the LT4KM require premium fuel? Isn't it simply a filter to remove the noise signature of the LT4 Crane gold roller rockers. Other than that simple filtering, wouldn't it function just like the LT1 KM?
There are factory engines made and sold that require only high octane fuel, because of the particular combination of compression ratio, coolant temperature, ignition advance, etc. These engines are clearly identified as requiring ONLY high octane fuel, and risk damage when run on low octane fuel.
Old Jul 30, 2006 | 11:34 AM
Severous01's Avatar
what he says...it's everything from temp to timing and compression. i wouldnt suggest running anything less than 92(which is what's premium in some states with 93 being "race gas") in any LTx engine or LSx engine. true it's (lt) based on the SBC which is what's found in trucks and older cars but it's a much higher compression running much more advance in timing. you'll lose performance with regular but you can reprogram the ecm to use it.
Old Jul 30, 2006 | 11:43 AM
matLT1's Avatar
IMO it just seems foolish to risk damaging your engine for the $.10-.20/gallon savings. That extra couple bucks per tank costs a lot less than the kind of damages that could occur from not having a high enough octane.
Old Jul 30, 2006 | 12:33 PM
You won't hurt anything with low octane fuels, as long as you don't go below 87-octane. The Owner's Manual points that out. The knock retard system will protect the engine, and will retard timing if the octane is not high enough. If you use lower octane fuel and the PCM retrads timing, you could lose performance.
Remember too... all this is based on what the factory assumed the average engine would look like after being used for a while. If you have heavy carbon buildup in the heads, you're going to need higher octane fuel for the same performance level. If your car is running higher coolant temps than the factory envisioned, if you have very high inlet air temps, or if you are below sea level, you need hight octane fuel.
If you are at high elevations, like Denver, the factory manual does not apply. The loss of air density reduces the octane requirement significantly. That's why you aren't likely to see every gas station at high altitude even carrying 93-octane fuel.... no one needs it.
Best thing to do is put a scanner on the PCM. Watch the knock retard under varying driving conditions. If you aren't getting any knock retard, you are using adequate (or more than adequate) octane. If you are getting knock retard, you need to rule out low octane fuel as the contributor, or just accept the knock retard and the lowered performance.
Old Jul 30, 2006 | 01:06 PM
In NJ, NY, PA, etc the normal premium grade is 93, with Sunoco stations selling a 94 super-premium. There are a few Sunoco stations that sell the Sunoco 100-octane unleaded racing fuel from the pumps.
Old Jul 30, 2006 | 01:45 PM
urbaNHunter44's Avatar
It DOES say it on the inside of the gas cap lid On both my LT1s it's said "use premium fuel" right there in the gas door, and in the owners manual.
I ran 87 one time just to see what would happen.. god I thought I fried a spark plug and had a horrible misfire LOL. I stopped at the nearest chevron and put 91 in it and apologized to my baby.
Old Jul 30, 2006 | 02:47 PM
camaro1fastz28's Avatar
i all way put 93 and some 110 that **** run real good when it get the 110 in it
Old Jul 30, 2006 | 03:37 PM
SS RRR's Avatar
Originally Posted by Z28Roxy
Yes. Driving through the highlands of the western US I saw a lot of "85 octane regular, 88 octane midgrade, and 90 or 91 premium".
That said, almost everywhere I've seen these days is 87 regular, 89 midgrade, and 91 premium. Driving from Los Angeles to Milwaukee on several different routes (passing through CA, AZ, NM, TX, OK, MO, IL, NV, UT, CO, NE, IA, SD, MN, and WI) I've only seen 93 octane as the common premium in Wisconsin. Even here some stations only carry 92 or carry 92 and 93 or 91 and 93. Most carry 93 only though.
Depends on the elevation of a given state as to what grades are available. Running 93 octane at 5000'+ele ain't going to do any better than 91.
Do you mean on the flip out door or on the cap itself? On a LT4 vette it's written on the flip out lid and I believe it also says it on the guage cluster? Can't remember for certain. Point being and as already said it doesn't say only. No doubt it'll hurt performance, but it isn't necessary to run premium for normal use.
Trick question perhaps? I've never heard of it being "only" a filter for the rockers. From what I've read and heard for years is that it listens to a narrower bandwidth off the KS over a LT1KM. However that was a long time ago and perhaps it was mere opinion from all sources. From what I just described it would seem it is a filter, but I don't understand how it could function just like a LT1KM if it filters out more noise than the LT1KM?
Old Jul 30, 2006 | 09:09 PM
You guys don't listen well do you. The b-body LT1 with the same exact shortblock but IRON heads which are less detonation resistant due to thermal retention is 10:1 stock but TUNED to run the same coolant temps as the aluminum and on 87 octane, works wonderfully. It is all in the tune the aluminum head LT1 at 10.4 could easily be tuned to run on 87. The average car buyer though equates octane with power and would have likely though the motor "low performance" with an 87 octane trecommendation or would have run premium anyway.
I myself ran a lot of premium through a few different cars that did not need it because I was young and ignorant, today the Caprice with the high compression gets it but the almost 200K mile Roadmaster wagon get 87 octane, runs great on long highway trips gets 23mpg with the air blasting and has run 15.5 at the strip with a raceweight over 4800lbs with VERY few minor boltons.
