LT1.. Whats This Part???
Old May 7, 2008 | 06:44 PM
kkfbody9's Avatar
The rubber hose i'm pointing to in the pics...coming out of the right side of the intake manifold on my engine is leaking air. Makes a hissing noise that goes away when i push on it.
What part is it and is it important or can i just leave it?
Thanks in advance
Old May 7, 2008 | 06:53 PM
jasonisdn's Avatar
pcv valve. replace it and replace the hose if needed.
Old May 7, 2008 | 06:54 PM
wrd1972's Avatar
Yup, what he said
Old May 7, 2008 | 06:57 PM
30696bird's Avatar
It's very important. Positive Crankcase Ventilation valve. It will cause a nasty vacuum leak fast! They are cheap as dirt ($3-$4). If you're hearing hissing from that area the hose is bad and needs to be changed. Even if the hose is not cracked it can be hard and not have a good seal. Also, the grommet could be bad (hard or cracked) so check it and make sure it's ok.
Old May 7, 2008 | 07:13 PM
kkfbody9's Avatar
OK, cool. My first thought was a PCV but im new to these motors. I know those are important, so i'll pick one up in the morning. thanks
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
