LT1 Water Pump New or Reman?
Old Apr 20, 2004 | 03:18 PM
350350's Avatar
Need the voice of experience here...
I'm replacing my opti and waterpump as soon as they get here... I'm ordering tomorrow. GM new waterpump is cashy!!!
Autozone reman units are much less cashy, but I don't want crap on my engine.
Has anybody had trouble with aftermarket reman water pumps? Is it worth the extra cash to get a GM new unit?
I've replaced 6,358 'Old' SBC waterpumps, and it was basically luck of the draw... They either last forever or they last a month. New or used. Never put one on an LT1 before...
Any words of wisdom???
Paul 'X'
Old Apr 20, 2004 | 03:21 PM
kgkern01's Avatar
I bought a new Autozone pump for my 96 Z28, kept the old one in the box. Once the pump went out on my 95 TA, since the new pump is lifetime warranty, it didnt cost me anything to replace the pump on the TA. Moral: Might be worth it in the long run to get the lifetime warranty New pump from Autozone.
Old Apr 20, 2004 | 04:11 PM
RENE95Z's Avatar
I put a reman on my car and I don't appear to have any troubles at the moment. I put it on about 6-7 months ago.
Old Apr 20, 2004 | 04:21 PM
fuzzyz28's Avatar
Bought reman from NAPA.
Much cheaper, 1 year warranty, and have had no problems.
Old Apr 20, 2004 | 05:35 PM
Dave88LX's Avatar
CSI electric.
Old Apr 20, 2004 | 05:39 PM
hoppy95dcmss's Avatar
Auto Zone Pump
I bought the life time warranty pum at Auto Zone. Cost $118.00 GM was $185.00 have had no problems. Real good looking pump.
Old Apr 20, 2004 | 07:28 PM
350350's Avatar
Re: Auto Zone Pump
My local dealer quoted me over $250 for a new GM pump!!!
Sounds like the remans are good stuff so far. I'll definitely get the lifetime warranty. How long does it take to change only the waterpump? That's more of an issue for me than the cost of the pump... The Lifetime Warranty doesn't cover labor!!!
Old Apr 20, 2004 | 08:39 PM
Water Pump
Well I am a little rusty on turning wrenches and this was the first I turned on my LT1 Impala. But I think it took me about 2 hours. Just remember to get all the air pump bolts that was the hardest thing. My impala has electric fans not sure about yours so just remove the belt and air pump and hoses. No big deal.
Old Apr 20, 2004 | 08:54 PM
kgkern01's Avatar
Make sure that you dont get any antifreeze at all on your opti, you dont want that going out on you as well. If you can drain your block, do that, as well as the radiator of course. I used an old towel to keep coolant off the opti. Not too difficult of a task.
Old Apr 21, 2004 | 09:49 AM
350350's Avatar
I'm replacing the Opti too, so just out of spite I may let the coolant douse it as I remove the water pump!!!
Old Apr 21, 2004 | 09:54 AM
Brent94Z's Avatar
Super Moderator
No experience with the remanufactured one but I just had to replace mine. When I went to AutoZone the reman was like $50. The new one was a little over $100. I asked the AutoZone dude what he thought and out of the corner of his mouth he said "you don't want the reman one". So, I spent the extra $$$ and just got the new one. Not saying the reman one wouldn't have worked fine but the local AuzoZone guy didn't have a lot of faith in it
Old Apr 21, 2004 | 09:59 AM
That's the spirit!
A brand new GM pump is ~$140 wholesale. GM PART # 12527741
Old Apr 22, 2004 | 10:51 AM
y5e06's Avatar
new
I removed an AZ reman pump off my C4 last month. It was on its way out and I didn't realize it until the need to remove it for opti replacement. Glad I found out before it left me stranded. half of the ball bearings in the back had fallen out and it made a grinding noise when spinning it by hand. Was not leaking as far as I could see.
needless to say I ordered the new GM unit for $140. the reman had less than 20K miles on it.
md
Old Apr 22, 2004 | 01:47 PM
med_reject's Avatar
I got a remanufactured one. The metal pipe (which connects to the rubber hose) slipped out of the pump (the hose was still clamped onto the pipe). I used one of those weld compounds (cant remember what it was called) and hammered the pipe back in, never had a prob since (1yr ago)
Old Apr 22, 2004 | 03:14 PM
LT1TONY's Avatar
I had a problem with a remanufactured from Napa. The propeller spun on the shaft. It was on warranty and got another one and have no problems with it.
