LT1 Valve cover options?
I am looking for a direct fit LT1 valve cover? I was wanting to go with the fabbed Canton's untill I read about all of the problems people are having with them? Will LT4 Black composite valve covers fit on LT1 heads? I know the
LT4 covers require studs, screws, new oil cap? Any other options out there?
Thanks,
Steve
Thanks,
Steve
Thanks,
Steve
Thanks,
Steve
I noticed that they dont seem to have the opening for the pcv, but they fit just fine on those iron head lt1s. I would think that they would fit fine on a regular lt1 but i dont know for shure. And here is a pic of the car just for fun
I hope this helps.
the composite lt4's are nice... I have a set.... they require no grinding for 1.6 rockers, they suppress valvetrain clatter (which can be detected as knock), and imo, they are the best looking valve covers
Try GM Parts Direct, I believe the part numbers are as follows:
LT4 valve cover, LH = 12552321
LT4 valve cover, RH = 12552322
Or maybe one of these guys can get you a set: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
what about corvette lt1 valve covers? Don't they look different than the standard lt1 cover? I think they are metal though. Someone please enlighten me on this as Im about to get a set out of a 93 vette to swap mine with.
Try this:
http://www.camaross.com/forums/showthread.php?t=504518
Scroll down that post, I have a link to my pics of the Proforms on my engine
Just to let you know 92, 93, 94, 95 composite valve cover DO require a little grinding to fit roller rockers, the 96's are fine.
Jul 4, 2005 05:00 PM
