LT1 Top End noises and misses
Old Sep 14, 2008 | 08:11 PM
deerslayinrenek's Avatar
I have a 95 Z28 and it's always had a rattle when it starts up then goes away. Well tonight i was headed somewhere and my car picked up a miss, i stopped and it has a noise on the drivers side. I don't really know if it is a bad lifter or a bent push rod. I don't really know anything about the internals of these. Do these have roller rockers and cam or what all do these have. How much work is involved in removing the intake on an lt1. I'm planning on taking the valve cover off tomorrow and having a look at the problem but i just wanted to get a few answers til then. Thanks Guys....Mike
Old Sep 14, 2008 | 11:17 PM
mrmint69's Avatar
Yes. I would pop off the valve cover and take a look. The drivers side is pretty easy and the passenger needs the alternator moved on mine. I would remove the drivers side and check that first.
Old Sep 15, 2008 | 02:15 PM
well it def sounds like it's coming from the drivers side, just got off work so i'm headed out to check things out
Old Sep 15, 2008 | 02:21 PM
87bandit's Avatar
hold a screwdriver to the valve cover with your ear pressed against the handle, this will help centralize the noise
Old Sep 15, 2008 | 04:12 PM
well I think I got off easy this time, the rocker popped off the pushrod. Not sure why this happened but it back on and runs good again....Thanks Guys for the help
Gtpguy
Jan 26, 2015 04:50 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
