LT1 Tech questions
Old Oct 4, 2004 | 09:03 PM
94z28_LTI's Avatar
Exclamation LT1 Tech questions
Hey guys great site you got running here. Was wondering If I could get some answers to a few questions about my LT1. Does anyone know the max lift a stock valve spring will take? Has anyone ever used the edelbrock LT1 performer cam. part #2108? What kind of gains will I get from a 1.5 roller rocker setup? How much HP is gained from a dual exhaust setup, headers and flowmasters? and finally does anyone have suggestions to squeeze extra hp out the engine with spending a bunch.
Thanks A lot guys
Old Oct 4, 2004 | 09:19 PM
n2ceptor's Avatar
Re: LT1 Tech questions
Welcome to the Site.... The stock spring are good to around .490, I believe... The Edelbrock cam is basically like a LT4 Hot Cam... Do you mean 1.6 ???? Exhaust varies between 8-30 HP, depending on set up....
Use the search function.... Most of you questions have been asked in the past....
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Nov 23, 2014 10:33 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
