LT1 swap wont start. PLEASE HELP!
Old Aug 23, 2003 | 01:03 PM
sinner's Avatar
Unhappy LT1 swap wont start. PLEASE HELP!
here is a previous post for reference:
http://www.thirdgen.org/techbb2/sho...65&goto=newpost
now its all put together. it has spark but wont run.
the fuel pump has 43psi
the motor will run if you spray carb cleaner in the throttlebody but wont run without it. the noid light is bright when car turns over, but dim on carb cleaner, and goes out when running gas from fuel pump.
any ideas?
this car is driving me nuts, and any help will be appriciated
oh, yeah, its a 95 LT1 in a 92 'maro
Old Aug 23, 2003 | 01:16 PM
joeSS97's Avatar
The link doesnt work. Are the injectors getting power?
Old Aug 23, 2003 | 01:37 PM
madwolf's Avatar
Yep, link doesn't work. Did you disable VATS from the PCM?
Old Aug 23, 2003 | 01:59 PM
sinner's Avatar
http://www.thirdgen.org/techbb2/show...15#post1453215
http://www.thirdgen.org/techbb2/show...80#post1452380
http://www.thirdgen.org/techbb2/show...ight=optispark
i hope these work.
the noid light indicates the injectors work great when turning over, but key in on position the light goes real dim
i have used a vats disable, yes.
could it be the optispark crapping out?
Old Aug 23, 2003 | 02:04 PM
Timberwolf's Avatar
if it was, the carb cleaner wouldn't make a difference
Old Aug 23, 2003 | 02:10 PM
sinner's Avatar
ok, well one of those links i posted a guy was haning a similsr problem and thats what it came to, so its an idea, any other ideas?
Old Aug 23, 2003 | 02:23 PM
turbo_Z's Avatar
did you test to see if there was fuel in the fuel rail but pressing down on the shrader valve?
Old Aug 23, 2003 | 02:38 PM
sinner's Avatar
i will, and ill post it
Old Aug 23, 2003 | 03:22 PM
sinner's Avatar
yep, its got fuel
any ideas?
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
