lt1 swap in a 240sx
Old Oct 24, 2008 | 09:11 PM
djexotic08's Avatar
lt1 swap in a 240sx
how hard is it to put that motor in the nissan 240sx s/13. i'm just wonding if you ask because i see alot of ls1 but no lt1?
Old Oct 25, 2008 | 01:26 PM
94arcticwhiteM6's Avatar
for the money and effort required it would probably be easier just to do the
LS1 swap. unless of course you have a wrecked z28 or trans am just hangin out.
Old Oct 25, 2008 | 02:33 PM
djexotic08's Avatar
hell, i see them one car at this one junk yard just sitting their waiting for someone pull that motor out!!! but what so hard puttin in a lt1 in the 240. the wiring?
Old Oct 25, 2008 | 03:15 PM
1994TransAmGTz's Avatar
ive seen a gen 1 Lt1 in a rx7 and the guy said it was simple to install you would just need pcm and wiring kit in witch painless makes a nice replacemet wiring harness and the mounts are pretty simple to fab your self but that Rx7 is early 80s model and it runs low 11s in the 1/4mile
Old Oct 25, 2008 | 03:47 PM
djexotic08's Avatar
then it must be simple to do this swap. i'm just wonding because i someone who some idiot hit my car really bad. bad enough that the body is no good beside the motor and tranny. then i will do a monster 240 build that is only use for is drag not drifting!!!
Old Oct 25, 2008 | 04:51 PM
yep drifting is for the cute 4 bangers drag hase been v8s for life that should be a nice project and will be a sick 240
Old Oct 25, 2008 | 08:23 PM
djexotic08's Avatar
i can see it now when i open my hood and let these 4 banger's know that i mean business. if a sr20,rb36,and a vq35 ain't enought. then you must came over to the America muscle motor. hell the much horse power i can get this lt1 going. i don't need no nos or a turbo. the body is going to be light as hell. which might hit easy 12's down the track!!!
Old Oct 26, 2008 | 02:55 AM
but ofcourse there are some 4 bangers out there that are nasty and **** me off some time why im boosting my lt1 so they can eat it hard lol
Old Oct 26, 2008 | 03:58 AM
TGK's Avatar
TGK
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
I'm sure it could be done, as long as you got the doe. Like you said a lot people do it with ls motors. I know hinson supercars or w/e charge like 8 grand or something minus engine and tranny(referring to ls1).
Anyways, if you have a spare f-body and a s14/13 it probably wouldn't be too bad. You'll probably lose your 50/50 weight balance if you put it in an s13 though. Also, money always helps and the ability to do work yourself. As for the imports, make sure none of them are ls1 swap'es. They are being put in supras, 240's, rx-7s, and everything now-a-days. Might suprise ya.
Old Oct 26, 2008 | 04:05 AM
TGK's Avatar
TGK
Yea, a friend of mine put a carb'd vortec 350 w/turbo 350 in a 2nd gen rx-7. We ran it against my z28(mostly stock) with his being all stock too from a slow roll 2 times and he pulled me both times. I think a big part of it was the stock 4.10 in the 7 vs. my stock 3.23's. It was funny though, because they just fabbed up some exhaust and there was like 1 - 1 1/2in. of ground clearance and when it would shift the exhaust would smack the ground and spark lol
Old Oct 26, 2008 | 04:11 AM
TGK's Avatar
TGK
I think you meant the rb26. Ironic you keep talking about 4 bangers then 2 out of the three engines you bring up are 6's. Also, the italized sentence doesn't make sense to me.
Either way, good luck with the swap if you decide to do it.
Old Oct 26, 2008 | 06:33 AM
yes i do have to say the rx7 i saw was indeed sick with its 18" inkys
Old Oct 27, 2008 | 08:00 PM
Mr_Bond's Avatar
Saw one over here
http://www.ls1tech.com/forums/showthread.php?t=1005165
Old Oct 27, 2008 | 10:16 PM
djexotic08's Avatar
after i get this car finish. i am going to think and go to the drawing board about this 240 monster drag car. after seeing the picture's. it look straight forward from the fab work and wiring.
Old Oct 27, 2008 | 10:27 PM
Zack's Avatar
for any project, put aside a budget, then double that-THAT is what it will cost you
now the reason why you see so many ls1 and not lt1 is because the ls1 is a better motor. no opti to worry about, aluminum block(lighter) and more power of the bat
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
