lt1 spring specs
Old Jun 13, 2007 | 05:41 PM
RC_CADMAN's Avatar
lt1 spring specs
im looking to get new valve springs for my 95 lt1. what is the size and and other specs for them?
Old Jun 13, 2007 | 05:49 PM
AZ2ENVY's Avatar
Theres several different types of valve springs you can get for your LT1 .
It all depends on type of cam your running or planning on running . But
whatever you do DO NOT and i cant stress enough DO NOT run Comp
Cams beehive 26918 valve springs ! The 26918 springs are having numerous
failure rates and has costed a handful of people motors already
Old Jun 13, 2007 | 06:21 PM
RC_CADMAN's Avatar
well for now im looking for just stock sizes. im trying to pick up a cheap set until next year when i rebuild it completely.
Old Jun 13, 2007 | 06:37 PM
AZ2ENVY's Avatar
Are you doing a cam ? Just curious to why you wanna replace stock
springs with a new set of stock springs IMO if you are
just replacing the valve springs cuz of mileage then just go for some
patriot golds . Do it right the first time so you wont have to re-purchase
another set of springs when you do a rebuild .
BTW cheap is NOT the direction you wanna take when messing around with
the valvetrain . This is definately one area that price makes a difference .
Old Jun 13, 2007 | 06:41 PM
mdacton's Avatar
diameter is 1.25 a 1.26 will fit the locators and retainers
not sure on the pressures....LT4 ones would work fine.
1.78 is the factory installed height
Why do you feel you need them? If you have a stock cam then I wouldn't bother with em
Old Jun 13, 2007 | 06:47 PM
RC_CADMAN's Avatar
well there is some tapping coming from the left valve cover area. im thinking that it was the rockers but they seemed fine. so then i figured i would replace the valve train. i can pick up the parts on ebay pretty cheap. so when i said cheap i mean i dont want to spend $200 on a set of springs when im going to put a hot cam kit in it next year. cant quite afford it yet. so im just trying to fix the problem.
Old Jun 13, 2007 | 06:49 PM
mdacton's Avatar
springs don't tap
maybe a lifter
Old Jun 13, 2007 | 06:50 PM
RC_CADMAN's Avatar
see thats what a friend of mine told me. hmm. do you think if i change the lifters i should change everything else?
Old Jun 13, 2007 | 06:51 PM
mdacton's Avatar
try to find out what lifter it is.......
no need to replace the other stuff
Old Jun 13, 2007 | 06:53 PM
RC_CADMAN's Avatar
well is there a way i can figure out which one without taking off the intake manifold?
Old Jun 13, 2007 | 06:55 PM
mdacton's Avatar
try to listen with a stethescope
or just buy a new set.....if you have to take it off anyway
Old Jun 13, 2007 | 07:00 PM
RC_CADMAN's Avatar
Smile
ill try that thank you
Red_94Formula
Jan 22, 2015 12:17 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
wytblur
Mar 2, 2003 03:40 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
