LT1 Seems to be Running Hot
Old May 6, 2008 | 01:23 AM
jdub4105's Avatar
I have a 97 Camaro Z28. I noticed that in stop and go traffic my temp. rises ABOVE the 210 middle mark. Actually closer to the red zone, but never in it.
I recently put a 180* thermostat in it, and also checked/added coolant.
What could be causing this? How can I fix it?
Old May 6, 2008 | 02:03 AM
bombebomb's Avatar
Maybe air in your system? Also make sure your fans are kicking on. I know the reason mine was overheating is from fans not kicking on.
Old May 6, 2008 | 02:24 AM
Counted Out's Avatar
My fans don't turn on until my my temp reaches the orange (red on other years) mark. So I don't think that's his problem.
The stock thermostat is 180* so I don't think that would cause it.
Old May 6, 2008 | 06:59 AM
Pontiac_97's Avatar
bleed the air out of the system.
Old May 6, 2008 | 07:01 AM
Sounds normal and hopefully you put in the correct, long LT1 specific thermostat.
Old May 6, 2008 | 07:50 AM
Red93Camaro's Avatar
isnt that normal? cause youre in traffic theres no air going up the air ram underneath the car?
Old May 6, 2008 | 07:53 AM
93transam1234's Avatar
Sounds like you low speed fan is not working....
TO the Orginal Poster:
Try getting some Water Wetter from the parts store, when i had my car stock that stuff really did a good job on keeping the car cooler.
You also might want to get the coputer programmed to turn the fans on earlier.
Old May 7, 2008 | 07:18 AM
2000GTP's Avatar
I don't know, from what you are describing, it sounds like a normal operating temperature.
Old May 7, 2008 | 07:33 AM
Stl94LT1's Avatar
Your cooling fans don't activate until 226*/237*.
Old May 7, 2008 | 08:25 AM
slomarao's Avatar
you can get a 160 thermostat and a switch to turn the fans and on/off whenever u want. Should help.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
calaban
May 18, 2020 06:43 PM
Collector Car
Dec 17, 2014 01:12 PM
CLEAR
Aug 30, 2002 07:49 PM
