lt1 in second gen camaro.confused on wiring
Anyone Have A Wiring Diagram For 96... Need Asap
i have the motor in and ready, the wiring is confusing me, should i use the whole harness, or just bits and pieces, really need a wiring diagram if anybody has one. but are there any problems i should be concerned about once complete. and just so u know i have read ultimatez's swap... im also using the 96 gauges and all but my likely my old headlight to taillight harness.. 96 lt1 in 71 camaro
Re: lt1 in second gen camaro.confused on wiring
I would use the whole underhood and engine harness and remove whats not needed.
I recently put an 94 LT1 and 4L60 E (2000 LS1 4L60 E) into a 91 S-10 pick-up. I used the compete engine harness and most of the underhood accessory harness (from the fuse box underhood to fusebox under dash and to PCM).
Shoebox has a nice pinout and basic wiring diagram for F-body LT1s.
http://shbox.com/1/schematics_wiring.html
ChrisFrez
Dec 21, 2014 09:47 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
