Lt1-SBC timing chain
Old Sep 16, 2008 | 11:48 PM
wht94formula's Avatar
I've heard that you can remove the wp. drive, and weld the timing cover and go from a lt1 timing chain to a SBC timing chain. Does anyone know if this is true, and do you have pics?
Old Sep 17, 2008 | 02:45 AM
cnorton's Avatar
Plug the hole in the timing cover (welding it would certainly accomplish the same thing), remove the WP drive gear, and use a timing chain set from a pre-LT1 roller cam small block application. You will probably need to grind additional clearance on the inside of the cover in a few places around the circumference of the cam sprocket. You won't know exactly where or how much until you mock up the chain and cover. It's not a big deal unless you ignore the fact that the chain is rubbing against the back of the cover.
Old Sep 17, 2008 | 12:26 PM
Projectz28's Avatar
Moderator
You can use one if you set it up right. As mentioned the cover usually needs to be clearanced to avoid rubbing the chain/sprockers. I had my cover welded shut but I have heard of others just using a freeze plug. obvously you need an electric wp as well.
Old Sep 17, 2008 | 06:43 PM
Thanks guys, One of the guy over on FAST which is my local board pulled through as well and told me, but didn't say anything about clearancing the cover (which is no big deal for me) I will try and remember to do a write up on it and post it up on here and FAST. I appreciate your knowledge. Thanks.
Old Sep 17, 2008 | 08:05 PM
1redTA's Avatar
re
I used a double roller RollerMaster chain from Scoggin Dickey just fine, also used a freeze plug and some hylomar on the hole. Art
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
