LT1 rebuild
Old Apr 23, 2005 | 07:56 PM
92/95TransAm's Avatar
LT1 rebuild
i am getting ready to rebuild my LT1 out of my 95 trans am. i was looking at the sealed power engine package from summit racing it comes with everything including forged pistons for 529. i want to put a little bit bigger than stock cam in it. it is a daily driver and i sometimes take it to the track. im not really wanting to aspend alot of money on a stall converter and all of that kind of stuff. i just want a little bit more power and some more rumble at idle. what are good choices for a cam?
Old Apr 23, 2005 | 08:03 PM
Re: LT1 rebuild
if i go with the cc305 will i have to replace valve springs and rockers or anything like this
Old Apr 23, 2005 | 09:06 PM
Robs97Z28's Avatar
Re: LT1 rebuild
yes, both of the cams will need new spring. I would replace the stock even if I wasn't going to replace the cam. LT4 spring are cheap and are much better then the stock ones.
Old Apr 24, 2005 | 08:57 AM
Re: LT1 rebuild
where is a good place to locate a new set of LT4 springs or eqivalent for a good price
Old Apr 24, 2005 | 10:49 AM
TransAm9585's Avatar
Re: LT1 rebuild
ANother idea for springs if your not going with a huge cam is useing the LS1 springs. You can use the LS1 springs just need to buy retainers and such to use them on the LT1. Just a price effective alternative if you find a set of cheaper LS1 springs. Thats what im using on my new LT1 build with hot cam.
EDIT Combination Motor Sports would be a great place to get your springs/rockers at a good deal and they will even hook up with alot of information.
Old Apr 24, 2005 | 10:55 AM
Robs97Z28's Avatar
Re: LT1 rebuild
http://www.sdpc2000.com/catalog/3533...Spring-Kit.htm
Old Apr 24, 2005 | 11:07 AM
sssalah's Avatar
Re: LT1 rebuild
The hotcam kit includes everything needed including cam, rockers and spring kit. This's a sweet little cam with a very good price, and what's good is that it's billet which is more durable then the cast comp cams.
Old Apr 25, 2005 | 09:26 PM
Re: LT1 rebuild
i found the LT4 springs and retainers for like a total of 50 bucks brand new are these springs enough for the hotcam or should i go bigger?
Old Apr 25, 2005 | 10:57 PM
Daryn95Z's Avatar
Re: LT1 rebuild
224/230 is my vote, I had that cam in my car for a while and it was a great daily driver/ weekend drag car.
Good low and mid range power, also had a nice lope to it.
I just rebuilt my motor w/that kit and a few other things, it seems to be pretty nice kit for the money.
Old Apr 26, 2005 | 08:07 PM
Robs97Z28's Avatar
Re: LT1 rebuild
They are the same spring the came in the hotcam kit.
Old Apr 26, 2005 | 09:23 PM
dover179's Avatar
Re: LT1 rebuild
CC306 Not nearly as big as everyone says. Awesome cam, Combination Motorsports will hook you up with all you need.
Old Apr 26, 2005 | 09:51 PM
mebanditws6's Avatar
Re: LT1 rebuild
Since you're going for a stock type rebuild, you'll be spending money to at least resurface the heads, new valves, new seals, etc. Why not consider Lloyd Elliot's stage 1 cam/ported head combo? The cam will be similar to the hot cam in terms of drivability, but it's custom ground to the heads. This is basically easy 350+ rwhp that you'll only need to spin the motor barely past 6k to get. just thought...
Jason
Old Apr 26, 2005 | 10:52 PM
Re: LT1 rebuild
what is the 224/230 cam? where can i look it up to get specs on it?
so far i have come up with about $850 dollars in parts shipped. this is including oil pump cam(still kind of undecided) bearings rings pistons gaskets valve springs and retainers. anything i am missing? what size bore should i go with? the machine shop said $150 for anysize bore all 8 cylinders. i am going to re seat the valves at school. i also plan on pocket porting the heads. i cant afford a head cam package becaus this is still my daily driver.
Old Apr 27, 2005 | 12:01 PM
Daryn95Z's Avatar
Re: LT1 rebuild
Give them a call, they know what they're talking about.
It's where I got my parts from.
Old May 4, 2005 | 01:09 PM
carolinacasper's Avatar
Re: LT1 rebuild
I have a stock '93 lt1 valvetrain with the stock hardened pushrods.
I'm putting in Aluminum 1.6 ratio NSA Roller Rockers in. I have the polylocks and hardened guideplates as well. I'm upgrading to the lt4 valve springs...do I need to buy anything else? Will the stock retainers work?
