LT1 R&R engine guide
Old Dec 12, 2004 | 09:11 PM
turbostud2's Avatar
Talking LT1 R&R engine guide
Anyone know of a good site or has info that shows how to R&R an LT1 in and f-body from the top? I would go through the bottom but dont have a lift. Thanks Kyle
Old Dec 12, 2004 | 11:03 PM
Re: LT1 R&R engine guide
You don't need a lift. You must have an engine hoist to pull it out the top, right? The same hoist can be used to lift the car up to take it out the bottom. I took mine out the bottom with nothing more than a floor jack and some creativity.
Old Dec 12, 2004 | 11:14 PM
blazzinbird's Avatar
I still would like to know what type of creativity you used rob, cause i dont have a cherry picker, im going to have to borror one
Old Dec 12, 2004 | 11:40 PM
I admit to being a little nervous about it, but I used some scrap wood as an extension to get enough lift from my floor jack to raise the front of the car 3 feet off the ground. I followed along with jack stands as the car was being raised. The stands had to be on top of my ramps to be high enough. I carefully jacked under the structural member running under the radiator (with the k-member unbolted, so as not to have the weight of the engine on the front end). All this was done slowly with constant visual checks for problems.
When I started, I had driven the car up on my ramps. With the k-member and shock tower bolts out, I jacked under the member to be able to remove the ramps under the wheels. After placing jack stands on the body behind the front wheels, I could lower the engine and k-member to the ground. I then proceeded to raise the body up as previously mentioned. The engine and k-member assy stayed on the ground as the body went up enough to roll the assy (with wheels on it) out from under. (you will need a dolly, roller skate , etc. under the tranny-or since you are not using the floor jack now, you can use it under the tranny).
Old Dec 13, 2004 | 12:09 AM
Thats kind of what i was thinking rob, ill try to get a picker, i fi cant ill prob do so mething like you did, and be very careful of course
Im wanting to roll the whole assy out with wheels still on
Old Dec 13, 2004 | 07:49 AM
Ken95Z28's Avatar
Engine Removal
I wrote this up about two years ago and have done this ever since.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
