lt1 question
Old Nov 17, 2007 | 08:24 PM
shadsta's Avatar
lt1 question
advanced induction would not cnc my lt1 heads they tried to sell me a new set any suggestions
Old Nov 17, 2007 | 08:30 PM
JooneJune's Avatar
They tell you why...
Old Nov 17, 2007 | 08:45 PM
shadsta's Avatar
exhaust ports were weak,already had valve job,been hot
Old Nov 17, 2007 | 08:50 PM
mdacton's Avatar
then you need a new set of cores.
Be glad they told you so you didn't end up with a crooked valve job, cracked guides and holes burned though runners
Old Nov 17, 2007 | 08:57 PM
shadsta's Avatar
afr heads on ebay 2 grand without a cam, or go with ai 2700.00 with cam
Old Nov 17, 2007 | 08:59 PM
mdacton's Avatar
Ai.
Old Nov 17, 2007 | 09:25 PM
96capricemgr's Avatar
I had someone try and sell me bad castings when I was looking for aluminium cores, there are a lot of them out there, luckily another forum member told me in time that the guy had had massive repeated overheating problems before I sent any money otherwise I would have ended up in your position.
I think we are all sorry to hear you had bad cores, nobody wants to see anyone else with expensive paperweights but now all you have into them is shipping costs not $1000+ worth of machining.
overheated causes them to get soft with a lot of potential problems resulting, if the valve job was aggressively cut maybe they needed new seats which would be a lot of cost and make better condition used castings a better alternative price wise.
If you don't believe them sure you can find a less careful shop willing to work them but don't be suprized if a head gasket goes and then wipes out the bearings with coolant filled oil.
Old Nov 17, 2007 | 09:39 PM
speed_demon24's Avatar
Posts like this make me glad that I was able to get one of the brand new sets of 643 heads on ebay a few months ago. Next time you buy cores try to work something out with the buyer to Guarantee they will be ok.
Old Nov 18, 2007 | 07:25 PM
shadsta's Avatar
im going to go with ai they are very helpful
Old Nov 18, 2007 | 07:34 PM
shadsta's Avatar
what hp are you running with that m6 with 3.73's? the heads i sent them came off the 95 ta i bought the guy told me it just spun a bearing
Old Nov 18, 2007 | 07:49 PM
Spinning a bearing may have been the final death of the motor but if the heads had a valvejob before I would bet one way or another he had overheated it and had the heads reworked a little during that repair and the shop who did that work did not hardness test them so they went back on till the motor died again.
Actually it is possible he had blown a head gasket and the resulting coolant in the oil damaged the bearings and that would cause eventual failure, we have no way of knowing at this point but this is a reasonable guess.
Old Nov 18, 2007 | 08:04 PM
I'm in the middle of putting everything together now, hopefully I'll have some dyno #'s and track #'s in around a month. I still have a few parts I want to get before I put it together. The quality on these heads is amazing though.
Old Nov 19, 2007 | 07:17 PM
shadsta's Avatar
about what does it cost to get a pcm tuned
Old Nov 19, 2007 | 07:19 PM
mdacton's Avatar
$175 from pcmforless I think.......look them up
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
