LT1 opti, electric water pump question
As mentioned above, dielectric grease is meant for electrical connections and things of that nature. It's main purpose, to my knowledge, is to prevent corrosion (by sealing out moisture) and inhibit conductivity. Thermal compound, on the other hand is generally either dark gray, or bright white. It's use is to dissipate heat. I believe radioshack carries it, I haven't seen it in any parts store, though.
Speeds8erM-1
Jul 18, 2002 11:36 PM
