lt1 OBDII tuning
Old Mar 5, 2008 | 12:37 PM
TJ Chapman's Avatar
lt1 OBDII tuning
is it possible with and OBDII to have a well built street lt1 with ported heads and such and LT headers, ory, and o2 sims, and by tuning the computer, still pass an emmisions test. all they do on 96 and above cars is plug in anyway, so if the sims tell the comp that there are cats, and your computer is properly tuned for what u have, will these testing facilities think everything is remotely ok and pass you (general idea i realize everywhere is different but u think its possible?)
Old Mar 5, 2008 | 12:41 PM
2000GTP's Avatar
Pretty much, with the plug in test, as long as you don't have a check engine light and you are not above the acceptable number of "not ready" statuses, you should pass.
Old Mar 5, 2008 | 05:46 PM
96capricemgr's Avatar
Talk to your tuner but I think some of them can make it pass without having to buy O2 sims.
Old Mar 5, 2008 | 05:55 PM
The Engineer's Avatar
Programming out the rear O2 sensors is a common practice for LTX cars with-out Cats. And, more common and cheeper than the rear simulators.
WD
Old Mar 5, 2008 | 07:21 PM
MeanGreen97Z's Avatar
WD
True... but you don't want a not ready status. I have simulators. I will be putting cats back on my car though.
Old Mar 5, 2008 | 09:29 PM
TJ Chapman's Avatar
"not ready" status is what exactly?
Old Mar 5, 2008 | 09:35 PM
Like I said I believe some tuners have found a way to make it pass without sims.
"not ready" means the pcm is not giving something a passing report but not a failing one either. To an inspection tech this looks like maybe you reset the computer down the block to hide trouble codes and the code maybe just have not reset.
Old Mar 5, 2008 | 09:44 PM
TJ Chapman's Avatar
oh that makes sense thanks
Old Mar 6, 2008 | 05:34 AM
Green96Z's Avatar
Nope. At least in CA, you still get tested with the sniffer and the plug in. With no cats, you will not pass the sniffer. So you might want to confirm how cars are tested in your county.
Old Mar 6, 2008 | 05:44 AM
2000GTP's Avatar
Thats something he should call and find out about. But I doubt WI is as strict as CA.
Old Mar 6, 2008 | 12:33 PM
TJ Chapman's Avatar
its not as strict as california, ive been to the test facility with my old mans 04 dakota and its just a plug in and no sniffer
Old Mar 6, 2008 | 12:37 PM
Dave1980's Avatar
CA just sucks for their Hitler method at emissions that is all.
If you look under your states emmision laws, it should state how many not ready flags are allowed. More are allowed for 96-99 in Texas.
Old Mar 6, 2008 | 05:14 PM
Don 97 SS's Avatar
Also be advised that state emission laws and testing procedures can change and when they do change they get stricter and not easier. Just because you live in an area that today you can pass doesn't mean you can count on it next year. I have personally experienced this when I lived in NC.
Old Mar 6, 2008 | 07:54 PM
I just became aware of another tuning option for OBD2 stuff. Thought this was interesting.
http://www.pcmperformance.com/flashkit.html
Old Mar 6, 2008 | 08:03 PM
Green96Z's Avatar
Yea I know, freaking liberal tree hugging hippies. Hey, if you don't like America then you can get out!
