LT1 Number 7 Plug WIRE
I'm having trouble getting the wire to the number 7 plug (back of the engine on the driver's side) out of my 95 LT1; any suggestions?
It seems to be tucked into some kind of shielding and I can't figure out how to get it out and where I should run the new wire when I finally do get the wire out.
Any help would be appreciated thanks
LittleCricket
LittleCricket
Re: LT1 Number 7 Plug WIRE
You have to remove the shield, fish the wire out and replace it back like it was. The shield is held on by two bolts. The front bolt will have to be removed, but the other can be just loosened (the shield is slotted where it goes over the bolt).
Thanks for the quick posts I just got done putting everything back together so this wire is all I have left.... I'll try everyones suggestions until something works.
...thanks again.
...thanks again.
is there anyway that I can take that plate all the way out... one end of the old plug got caught and I didn't realize it and it broke off inside that shielding... I know its going to be a pain in the a** now no matter what, but I'm looking for what my best bet is.
Wait the plug broke off? Do you mean wire? I cut the old one apart and then worked the new wire in by bending the heatshield and sliding the new wire in at the same time. If I were to do it again, I would take off the heat shield because it is probably easier. So answering you question, take the shield off (two bolts like shoebox said), take out new wire, put new one in, re-attach heat shield. Bham!
sleeperZ96BT
Jun 5, 2005 09:33 PM
