Lt1 no start... No injector pulse, no spark, multiple problems mayby?
Old Apr 18, 2007 | 04:20 PM
tylert14's Avatar
I bought a 96 TA off a guy that put P/P heads, new opti, new wires, and new coil in and drove 91 miles then he went to start it one day and it sputterd and died. So I picked it up a few days ago knowing it would be a project... I open'd the hood and realized this guy did a not so great job.... I'm new to Lt1s, I've allways worked on gen I stuff. Helped my friend here and there with Lt1 stuff so I know a little. But this was bad lol. There was a MSD 6al box with a rat nest of wires and them little twisty wire connectors you use in your house wiring and medical tape lol. An MSD blaster 2 coil chilling on the intake. Like the old style one shaped like a redbull can. Plug wires in wimpy heat wrap laying allover the headers.
So I tore the MSD box coil and associated wiring out. Bought a coil from autozone, Autozone wires (will get better ones eventually), and put it all in (there were 2 badly burnt wires). So it don't start. Start testing stuff. No spark on any of the plugs or the coil wire and no ground pulse on the non pink/black injector wire (I don't have a NOID light). Took a spark plug out and it was dry after cranking it over.
The coil pigtail was missing and I've yet to find one localy so I'm using 2 small insulated female connectors slipped over the pins. Pink wire on the furthest right pin, green wire 2nd pin to the left.
So just now I went out and tested all the wires Harlan mentions in his No start diagnostic.
Unplugged optispark harness
red/black +
purple +
red +
pink/black _
coil (probed the wires while all coil and ICM wires still hooked up)
green grounded only when key off
pink + key on/ cranking
ICM (probed the wires while all coil and ICM wires still hooked up)
pink +
brown -
yellow -
green +
The coil wire had continuous power when i touch it with the test light.
Still no pulsing ground on the non pink/black injector wires.
So far the things I see wrong are...green coil wire is supposed to be a pulsing ground with the key on but its grounded only with the key off.
And the purple optispark wire is + and it should be - right?
So anyone got some insight on what I should check next? I've been trying to have this thing on the road "by tonight" for the last 3 days lol...
Old Apr 18, 2007 | 04:25 PM
WS Sick's Avatar
I would point to either the IGN module, Opti, or the wiring between the two, was the harness butchered.
Old Apr 18, 2007 | 04:36 PM
tylert14's Avatar
The wiring harness seems intact other than missing the pigtail.
I was thinking the ICM to, but that wouldn't cause the injectors not to work would it?
Old Apr 18, 2007 | 04:37 PM
tylert14's Avatar
Is there anyway to test whether the optical pickup in the opti is working or not other than the injector pulse?
Old Apr 18, 2007 | 04:50 PM
WS Sick's Avatar
The circuit for the injectors runs through the opti. and in a round about way the ign mod.
The opti gets a ref signal from the ECM and returns it. I don't have my T-shooting quide with me now, but Shoeboxs site has one.
http://shbox.com/page/index.html
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
